Old 10-19-2018, 11:36 AM   #1
dsraven
axle swapping and the Ford 8.8 stuff
just a couple of items here for the ford 8.8 axle that seems to be a common swap for our trucks.
there are those who will say you also need to upgrade the wheel bearings and axles because they have the C clip style of axle retainers and those can fail. that would be a personal preference but, thinking about it, how many ford vehicles, or any vehicles for that matter, have you seen that have lost an axle due to a C clip failure. maybe for the full on racer that would be a consideration. for most I personally wouldn't lose sleep over it as long as the unit is serviced and the fluid level check plug is located in a plane that allows for the stock level to be retained. some will also use a 90 degree fitting to allow the diff fluid level to be the same when the axle is rotated to allow for pinion angle to be correct with the rest of a home made driveline. some like to overfill the housing so the axle bearings always sit in fluid. personal preference. don't let the axles run dry is all.
the explorer came with an option for the larger axle sizes, posi, a pretty good ratio and disc brakes with a "top hat" style disc/drum (for the park brake) set up, drum brakes are also available for those who want that set up. the explorer came with a couple of sizes of stabilizer bars that go in a U shape towards the rear of the vehicle. the ford ranger has the stabilizer bars across the fron of the axle and the U shape faces the front. again, several different sized stab bars are available there as well.t
the pumkin is not centered in an explorer but if you plan to narrow the axle it becomes something to ponder because you can shorten the long side to be the same as the short side, then use (2) short side stock axles. that way the pumkin is centered and you can grab an axle from any scrap yard or a stock replacement from a gear vendor (suggested if the broken axle is the one that was actually started out life on the other side of the truck. apparently they get work hardened in one direction and don't like to have their mind changed). there are some 8.8's with a centered pumkin, look at the mustangs for this.
when cutting off the stock brackets, to end up with some bare axle tubes, be aware of the heat generated by that process. it could warp the axle tubes on whatever diff you would be using, be it the 8.8 or a 9", 12 bolt or whatever. the same goes for welding attachments or spring pads back onto the housing or axle tubes, take your time and let stuff cool off between welding blitzes. always put the ground clamp on the housing, never on the axle flange. the welding current can go through the axle or diff bearings and cause damage when that is done.
the axle flanges have the ford pattern but that can be taken care of pretty easily by redrilling the flange and brake rotors to the pattern desired and replacing the studs with the size you will run on the front axle.
there are a couple of sites that have some pretty good info here
the ranger station. poke around here for more info
https://www.therangerstation.com/tec...8_8-axle.shtml
https://therangerstation.com/tech_li...lorer8_8.shtml
retread has a few points with some links at the bottom
https://www.retreadtrails.com/blog/f88
the fabricators series has a few points as well as some links to other sites
http://thefabricatorseries.com/build...prelude-and-qa
the hotrod network did a story on it as well
https://www.hotrod.com/articles/ford-8-8-rear-end/
here is a copied/pasted track width chart from another site. here it is always good to measure from the actual wheel mounting surface rather than the backing plate. a short piece of bar or angle iron bolted onto the wheel mounting surface on each side of the axle will help you make that measurement more precise
https://www.crankshaftcoalition.com/...l_measurements
welder's series has many kits and individual brackets, rods, tubes etc if you want to fab up your own suspension or build other hotrod stuff. they are Canadian so the USD will buy you more
https://welderseries.ecwid.com/?_vsr...BoC2WcQAvD_BwE
hopefully this helps somebody out there looking for answers on a diff swap
