Old 10-19-2018, 03:12 PM   #1
blackhawck
xj steering shaft swap
Will the 87-95 jeep xj steering shafts swap to a 71 k10? What is the spline count/diameter, I'm showing a 13/16th 31 spine at my steering gear. Has anyone done this to a k10, is there a difference. Thanks in advance for any help before I head to the pick and pull.
blackhawck is offline   Reply With Quote
Old 10-20-2018, 10:00 AM   #2
70shortfleet
70shortfleet's Avatar
Re: xj steering shaft swap
It will not work. The diameter is about 23/32'' and the spline count is 36
70shortfleet is offline   Reply With Quote
Old 10-21-2018, 12:03 AM   #3
leddzepp
Moderator
leddzepp's Avatar
The splined end will fit our steering boxes...I have one and have test fit it. The problem is that the other end of the XJ shaft is a DD, and the steering columns on our trucks are splined, so it will not connect without an adapter of some sort.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
