Old 10-19-2018, 08:19 PM   #1
sweetk30
sweetk30's Avatar
1987 r-10 / c-10 engine wiring help ?
i am looking for a diagram for the 1987 c-10 305/700r4 at the big plug on the firewall .
i am trying to separate the tbi harness from the gauge/starter wires .
since i am going holley sniper and dont need the massive tbi wire pack anymore .
here is what i got to figure out .
pink / black tracer - goes to main tbi harness .
purple / white tracer - goes to main tbi harness .
solid lt brown - goes to tbi main harness . and no not the alt wire i got that one .
tan / black tracer - goes to tbi main harness
BIG pink - it goes to TBI coil plug . so i think its key hot and crank . ?
tan / white tracer - this is on the 2 wire oil pressure sensor top of engine behind intake .
orange - this also is on the 2 wire oil pressure sensor top of engine behind intake .
light purple - its going to the 700r4 trans plug .
just to be clear i have the common known oil pressure gauge single wire . its light tan/orangish .
all ends were labeled before i pulled this from the engine . as i had un-pluged the main harness at the firewall block when body was pulled .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-20-2018, 05:16 PM   #2
MikeB
MikeB's Avatar
Re: 1987 r-10 / c-10 engine wiring help ?
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-20-2018, 06:17 PM   #3
sweetk30
sweetk30's Avatar
already found that in search . but its for hei big cap dist and carb .
not going to work for the tbi stuff .
but i said screw it and cut them off but left a good length on both sides . capped the ends and left a few out for tie in feeds .
looks like there mostly power lines from the fuse box out .
Old 10-20-2018, 10:10 PM   #4
1957 Chief
Retired USAF
Keep all reds (12v constant) and pink (12v switched) and purple (starter).
Tan-oil press
Dk Green-temp sensor
You can prolly see not to cut the wiper motor wires
Everything else, cut and put heat shrink over. That's how I did mine.
Bubba
1957 Chief is offline   Reply With Quote
Old 10-21-2018, 08:36 AM   #5
homemade87
I parted a 87 gmc and every wire coming thru the fire wall behind the pass head is not needed . You can remove that complete harness inside and out of the cab . It is a independent harness for the tbi system . Has nothing to do with the starter wire and other electrical to make your truck work . All of those wires comes from behind the drivers side fuse panel beside the steering column .
homemade87 is offline   Reply With Quote
Old 10-23-2018, 08:09 PM   #6
Wwes
Correct above. Don't get rid of any of the wires on the fuse box plug, those control the starter, wipers, oil pressure switch, fuel pumps. They have nothing to do with the TBI. That harness is on the passenger side above the passenger exhaust manifold. You should be able to pull that harness and plug that opening.
Wwes is offline   Reply With Quote
Old 10-24-2018, 10:54 AM   #7
sweetk30
sweetk30's Avatar
done thread closed . . . no one is reading my info request .
Old 10-24-2018, 07:19 PM   #8
skyphix
I've been looking, I have hard copies but only for 1980 so that won't help you (since no TBI).
Does this help?
https://imgur.com/a/mvAAqrl
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
