Old 10-20-2018, 10:23 AM   #1
DJ_Baar
Question Door Strike Plate NON-HARDENING Seam Sealer?
O-K, I SNAFU'ed and didn't notice the seam sealer I used on first door striker was "HARDENING" - my BAD. It dried rock hard! Managed to get it all apart again and luckily noted before doing second door, (doors are OFF).
* Need recommendation on quality NON-HARDENING BODY SEAM SEALER to use so I can re-adjust the striker plates as required when re-installing the doors?
Don't need a lot & only found EASTWOOD Brush-able Seam Sealer, but heard there is a product you can actually kneed with your hands like play-dough?
Already done once, help me get 'er done right.
Thanks.
PS. Front fenders will be coming back off to hang the doors.
DJ_Baar is offline   Reply With Quote
Old 10-20-2018, 10:27 AM   #2
Shinysideup
Shinysideup's Avatar
Re: Door Strike Plate NON-HARDENING Seam Sealer?
Like 3m strip caulk?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 10-20-2018, 11:02 AM   #3
DJ_Baar
Dooohhh - had a "Homer" moment, found this on shelf when I put the other away. Yep, guess this IS my last major project?
And thank you for the reply Shineysideup, I was looking at that product online.
