Non-electric Quieter Fan Options
As everyone knows the standard factory cooling fan sounds like a jet at take off. WITH OUT going electric is there a quieter option? No over heating or other cooling issues, just wondering.
Thanks! |
![]() Join Date: Mar 2005
Re: Non-electric Quieter Fan Options
I don't think so. the noise pretty much corresponds to the amount of air flow. Hard to get one without the other. The quietest setup is probably a 7 blade fan on a thermo clutch assembly.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Thanks. I assumed there was no silver bullet but you never know.
Post Whore
![]() Join Date: Feb 2016
This has my vote too. I drove my Burban to work most of the summer and never heard the fan and the truck never got even warm. Best of both worlds. I can hear the fuel pressure regulator working and it is mounted on a fender well. What I'm trying to say it is pretty quiet inside and I'm sure I would have heard the fan.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: May 2012
Are you sure you don't have a flex fan? They are noisier than a jet, more dangerous too. Like said, proper fan and clutch, and proper shroud will be smooth and peaceful.
![]() j
White K20 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Agreed 100%. I wouldn't trade mine for anything.
Engine driven clutch style fans are alot quieter than non clutch direct drive fans.
1968 SWB Step Side, Big Block, 4L80E , Running! |
#8 | |
Thanks to everyone for their input. I always appreciate the willingness of members to help out a rookie. |
20' Daredevil (Ret)
You might have a non-thermal fan clutch.... or a defective clutch that is locking up too soon. Pics would help us figure out exactly what's on there.
Not so sure we all agree on what we all know, because I've got the giant factory AC 7-blade monster and shroud (and every factory piece) and it's honestlty pretty darned quiet. Maybe you've got a locked up clutch or a fixed fan?
I wasnt sure what views would help so I took a few without completely removing the shroud. the fan turns but not freely. Im almost positive it is a stock fan.
#13 |
Post Whore
Yup it looks like mine. If I was to guess I would say the clutch is causing the fan to spin faster than needed thus making it noisier than it should be.
#14 |
If that clutch is working properly the fan shouldn't make much noise. How does it feel if you turn the blade? I have 7 blade clutch fans on both my trucks. My hearing's not great but I do hear a lot other old truck noises(lifters, A/C compressor....) over the fan. That's standing in front with the hood up. Driving I hear road noise, wind, exhaust, but not the fan.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
#15 |
20' Daredevil (Ret)
First off, it sounds as though your clutch may be working properly -- that is, it turns but not too freely. It should feel like it's operating in molasses. Your fan does appear to be stock, but is it a 6-blade or 7-blade fan? I don't know how much noise a 6-blade makes, but my 18" OEM 7-blade is very quiet, barely audible, when the clutch engages. My truck has a fairly new Hayden #2747 fan clutch.
You have a thermal fan clutch (good) but it's a standard duty (smooth face with fins only around the outer edge) and you might be better off with a heavy duty. See all the extra fins across the face of HO455's clutch? That's an indicator of a heavy duty clutch. Good info on Hayden's website https://www.haydenauto.com/featured%...s/content.aspx. Basically, use a standard duty if your fan blades have a 1 1/2" pitch. Heavy duty should be used with 2 1/2" pitch fans, which is what yours appears to be. While a heavy duty clutch might help with engine cooling (you have not mentioned any problem with cooling / overheating), I don't think it would make your fan any quieter. So it might be info you didn't ask for and don't need! ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 10-24-2018 at 11:33 PM. |
#16 |
Hmmm, are you sure the fan is the source of your noise issue? Lots of stuff near the fan that can scream under load. Power steering, AC compressor, water pump, metal on flywheel cover rubbing, the list just goes on. Just saying. Maybe a bit of throttling with the fan unhooked. Get your stethoscope down there. I am now skeptical it's your fan.
![]() j
White K20 |
