10-22-2018, 08:08 PM | #1 |
Need help adding Clutch Pedal
Anyone have advice on converting my brake pedal assembly to a clutch/brake pedal assembly with hydraulic clutch. Is there a aftermarket setup that works well or should I try and convert the assembly I have by adding a clutch pedal ? I'm not sure if it's even possible. Lokar offers a direct fit assembly but looks like the clutch push rod is on the right of the brake pedal? I've seen photos where the the clutch slave cylinder is mounted on the right side of master cylinder on the firewall. I'm not sure how that's being done.
10-22-2018, 08:40 PM | #2 | |
The Older Generation
Re: Need help adding Clutch Pedal
Adding a clutch pedal to your existing pedal bracket isn't that hard. Most guys attach the clutch rod directly to the pedal arm. I think the easy thing to do would be to type "hydraulic clutch pedal" into the Google search box up above, click on the circle in front of "67-72chevytrucks.com and click on the Google3 button.. It will generate quite a few hits. Just make sure the thread you click on relates to the '67-'72 trucks. LockDoc
