Old 11-18-2003, 10:42 PM   #1
special70gmc
special70gmc's Avatar
Question master cyl/prop valve
what wqould happen if i was to use my drum drum 3/4 ton MC and prop valve with my new disc brakes? im kinda no really tight on money and i cant quite cough up the cash to pay for the last pecies. aso i have a late model MC but no prop valve could i use that? thank you -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 11-18-2003, 10:49 PM   #2
Glen
Your drum setup requires a 10lb residual pressure valve to keep the shoes out near the drum.
disc setups only require 2lb rpv valves.
the brakes would drag.
Glen is offline   Reply With Quote
Old 11-19-2003, 12:04 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Plus, on top of that,t eh reivour needs to be bigger on discs since there is no mechanical adjustment...the hyd make up the adjustments on them.
Old 11-19-2003, 12:25 AM   #4
cableguy0
plus ur truck wont stop worth a sh!t because disks require more pressure to operate than drums do. brakes are a very bad place to cut corners but im not gonna lecture u its your life and ur truck both in your hands. just wait till u can afford it and get a new master and prop valve
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-19-2003, 04:25 AM   #5
SEVEND2
SEVEND2's Avatar
I agree, DONT RUSH IT!
Remember its your Truck, Life, your passengers and others around you....
save up a bit longer and get little by little
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 11-19-2003, 04:27 AM   #6
SEVEND2
SEVEND2's Avatar
b t w - post you are looking for those parts on the parts board, you never know a Board member might just have a great deal for you......
and stage 2
Old 11-19-2003, 04:37 AM   #7
jose
jose's Avatar
Is there a difference between disk 1/2 ton prop valve and disk 3/4 ton prop valve ?
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 11-19-2003, 11:00 AM   #8
72MARIO
72MARIO's Avatar
Can you get a Adj. porp valve ? Summit selles them for like 50 bucks I think you need thoed tings that hold presssure in the lines though ... I don't know
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-20-2003, 12:55 AM   #9
Glen
I just wanted to clarify, Im talking about the "residual pressure valves" not Proportioning valves.
P. valves maintain the balance between front and rear braking.
RPV's retain 2lbs of pressure on the caliper pads and are usually mounted internally inside the master cylinder.
Drums again require 10lbs. of pressure to keep the shoe extended slightly touching the drum.
Old 11-20-2003, 08:52 PM   #10
Smitty
Smitty's Avatar
And the pressure difference between the two means that using the drum brake M/C you will have constant pressure on the calipers. Causing unnecessary wear to pads, glazed rotors, and lost gas milage.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
