Before and After
Internal door parts
Do you clean, sandblast, remove rust if you take any of the door guts out before you reinstall them?
I was going to run them thought the sandblaster, but was thinking that sand may cause more of a problem.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
#2 | |
The Older Generation
Re: Internal door parts
I don't blast them. I just clean them up by hand, lube all of the pivot points and channels and re-install them. Then again, I don't build show trucks, just drivers, so others may get more technical on them..... LockDoc
Before and After
Got it, not a show truck builder either. The blast cabinet seems like a quick fix, but just like the olden days, some things are best done by hand.
![]() Join Date: Aug 2004
I’m doing the same thing and won’t blast them. That sand will get into the pivots, it’s so dusty.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
I've been using a vinegar/water mixture to let them sit in for a bit, acts like a rust remover. Then I clean what that doesn't get by hand, and put a protective coating on and lube everything up. I made the mistake of blasting window regulator pieces once and it was more head ache then it was worth.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
Before and After
a little vinegar solution and a wire brush is all I will use.
