Old 10-25-2018, 11:39 AM   #1
Auroch
Auroch's Avatar
Sound system upgrades!
Music is huge for me, and a mono center speaker from behind the dash is not gonna cut it. How have you guys improved that in your truck? I've been looking at kicker panels and maybe hiding the sound system in the glove box. Keep the dash looking original. Anyway, hope to see some cool $#!t!
Auroch is offline   Reply With Quote
Old 10-25-2018, 12:02 PM   #2
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Sound system upgrades!
Go here.
http://67-72chevytrucks.com/vboard/f...prune=-1&f=111
There are all kinds of threads on center speakers.
I did a double 4" speakers that are held in place with the speaker bracket.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-25-2018, 12:31 PM   #3
sick472
sick472's Avatar
You should consider using a Marine Stereo Enclosure (sometimes called a weatherproof or waterproof stereo housing). This can be mounted under the dash, looks nice compared some of the auto "under dash housings", and you have a better chance of reaching it and seeing it compared to hiding it in the glove box. Make a radio delete plate that can take a couple gages (or not, maybe an extra cigarette lighter jack/USB port or two - for phones and whatnot).
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 10-25-2018, 01:59 PM   #4
Auroch
Auroch's Avatar
Originally Posted by Andy4639 View Post
Go here.
Oh nice! Didn't realize there was a whole section on the topic ha. Thanks.
Old 10-25-2018, 02:00 PM   #5
Auroch
Auroch's Avatar
Good call, I'll look into this. Thanks!
Old 10-25-2018, 05:12 PM   #6
demian5
demian5's Avatar
I have kick panel speakers and a bose sub from a 2010 tahoe where the jack is. Powering it is a 4-channel alpine amp. Sounds awesome and very space and budget friendly.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-25-2018, 06:50 PM   #7
darrellyates
Check the audio forum for suggestions. In the meantime, I've got a retro sound head unit, and a NVX 900.1 5 channel amplifier. Runs 6 1/2 inch speakers in the kick panels, and 5 1/4 inch in the cab behind the doors. Then, I built a sub box that is the same dimension as the gas tank, and mounted a 12 inch shallow mount sub in this box (I run a relocated gas tank).
Pure audiophiles wouldn't likely approve, but it works for an old fat man....
(pix loaded)
darrellyates is offline   Reply With Quote
Old 10-25-2018, 08:13 PM   #8
Greasey Harley
Greasey Harley's Avatar
Cut the dash
Cut the doors.
Small sub under the seat, or behind if you moved your gas tank
Mount tweeters on the dash, about where AC vents go
Do a professional job. Like, A REALLY GOOD JOB.
add dynamat
never look back.
Greasey Harley is offline   Reply With Quote
