Old 10-25-2018, 04:21 PM   #1
72velle
72velle's Avatar
84 fuel guage
The fuel guage on my 84 C10 works sometimes. Mostly it doesn't but when it does it is accurate. Single fuel tank. Is this a sending unit issue or wiring issue?
Thanks!
72velle is offline   Reply With Quote
Old 10-25-2018, 04:28 PM   #2
Bandit130
Bandit130's Avatar
Re: 84 fuel guage
Could be pin connection on back of gauge. You can remove, clean the 3 connecting pins with sandpaper and I used alcohol. Also sandpaper inside the clips and clean. This might help or be the issue.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 10-25-2018, 08:52 PM   #3
hatzie
Moderator
hatzie's Avatar
Re: 84 fuel guage
This is more often than not caused by a loose or missing tank to frame ground wire.
I had this happen when the rub strips on the tank were worn through in places and the tank occasionally made enough contact with the supports to ground the sender.
Easy enough to troubleshoot. Hook a set of jumper cables from a clean spot on the frame to a clean spot on the fuel tank pinch weld to provide a good solid temporary fuel tank ground. If the gauge starts to work then you found the problem.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
