![]() Join Date: Jan 2001
Throttle cable question
I have a K20 with a 350 Edelbrock 1406 carb and Edelbrock performer manifold. I swapped from a 69 to a 71 cab so the throttle linkage is cable rather than rods and I don't know what it is supposed to look like. I bought a 4X4 throttle cable and it seems to be about 2 inches too long. Also the cable seems designed to go into a round hole, not square like my bracket seems to be for. Has anyone else had this problem ? A picture would be greatly appreciated. Thanks
Bernie |
![]() Join Date: Dec 1999
i converted mine over to cable but you have the cab already set up so you wont have to make the mods that i did. but you might want to check out the SPECTRE throttle bracket. i think its universal, just a suggestion, not sure if itll work
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
Bernie,
The 4x4 cable will be shorter than the 2wd cable because of the fact that the engine is mounted futher back. The cable exits the cab, then the big round thing near the end of the cable goes through a bracket which mounts to the back drivers side carb stud. That's it. The bracket itself is available as aftermarket, or you could probably find one used someplace. I'm not sure how the throttle rod attached to the carb at the throttle end itself, but I'm guessing you'll need to make a change there as well. The 71-72 style cable will have a spring clip that pops over a little ball-stud. Brian |
Thanks for the replies. I have the SPECTRE bracket. I'll try again tonight. I must be missing something as far as the routeing of the cable goes. I have the 4X4 cable (I know because I origonally bought the 2WD
Bernie |
Project Junkie! Fishing Poor!!
Bernie, the 4X4 cables do seem a little long, but that is how they are from the factory. I believe this is to allow for movement of the engine without it pulling on the cable. We have replaced many of them here and they have all been the same. As for the bracket that bolts down to the driver's side rear of the carburetor, I would check around the wrecking yards if you can't get your aftermarket one to work. I used an aftermarket bracket for the one in my Blazer and it was tough to get it installed, but I was able to do it. I just used a large set of channel locks to press it in. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 10-04-2007 at 07:10 PM. |
