Old 10-25-2018, 08:30 PM   #1
Greasey Harley
Greasey Harley's Avatar
I need some help adding Power Steering to a 327
Looking for brackets, pics and/or part numbers to add a power steering pump to my 68 c10. 327 w short water pump.
I don't really want to switch it to the long water pump setup. I have a steering box. I think I know where to find a good, used pump.
Anybody got a source for brackets?
looks like I might need a different crank pulley?
Thanks, Russ
Greasey Harley is offline   Reply With Quote
Old 10-25-2018, 08:37 PM   #2
geezer#99
geezer#99's Avatar
Re: I need some help adding Power Steering to a 327
Try here.
http://www.alangrovecomponents.com/
Old 10-25-2018, 08:39 PM   #3
notsolo
notsolo's Avatar
I think a donor with all the brackets, pulleys, pump etc off any short water pump V8 would be best. Aligniment, getting pulleys to line up is tough...mounting holes already in the 327?
notsolo is offline   Reply With Quote
Old 10-25-2018, 08:44 PM   #4
rsavage
rsavage's Avatar
This is a stock set up. You can buy the double crank pulley that nestles in the single. Belt for PS pump goes to outside.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-25-2018, 08:56 PM   #5
Greasey Harley
Yeah, pulley pn is:3751232, they're available on fleabay
I would prefer original brackets, but might consider Geezers suggestion for an after market setup.
Old 10-25-2018, 09:26 PM   #6
kaycee
kaycee's Avatar
I got some brackets and pulleys ,my 327 has the ps belt on the inside pulley cant remember if its original setup or not .
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 10-25-2018, 09:57 PM   #7
palallin
I bought a whole truck to do this to my '67. Drivetrain was long gone, but a got it cheap, kept a pile of parts, and sold it to a salvage man for almost as much as I paid for it. I highly recommend the process.
BTW--and this part will make some guys on here scream--the truck was a '68 model with a small rear window.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-25-2018, 10:53 PM   #8
Chris_oz
Chris_oz's Avatar
I got a pump, mounts and crank pulley of ebay cheap cheap, all bolts straight up. All original and fits well. Just keep. An eye out on ebay.
Chris_oz is offline   Reply With Quote
Old 10-26-2018, 03:05 PM   #9
Greasey Harley
Originally Posted by geezer#99 View Post
Thanks Geezer,
It looks like that's the way I'm gonna go. I found the bracket and pulley for $95
I already have a pump, lines and steering box.
The entire upgrade should cost about $150 including fluid.
I've been meaning to do this for 4 or 5 years.
My wife always tells me, she'd like to drive the truck, if it wasn't so hard to steer.
..I hope she still lets me drive it on occasion.
Old 10-30-2018, 01:00 AM   #10
Greasey Harley
Got my Alan Grove PS pump bracket and 3rd groove pulley today.
Nice unit, heavy duty, fits great.
Painted it black and installed it. easy peasy.
Pulleys line up perfectly, It's pretty slick.
I can't wait to have power steering!
Old 10-30-2018, 07:19 AM   #11
Myoldtruck
Myoldtruck's Avatar
I did mine last year, well worth doing. Your going to need also a new pitman arm, a new rag joint. I found my pulleys on ebay for a gmc pickup. the pump and bracket i found at a you pull it junkyard, the steering box was in a box when i bought the truck. hardest part of the conversion was getting the bolt started at the motor mount.
Myoldtruck is offline   Reply With Quote
