Old 10-25-2018, 11:43 PM   #1
45thparallelc10s
ls swap
so I'm about to do my first LS swap on my '68 c10 swb. If I buy a painless harness will it plug into the factory harness? Also i am going with all porterbuilt level 3 dropmembers, does anyone know if i can use the factory oil pan or do i need to go with a lowpro oil pan? I would appreciate any help thank you. Just started looking into this so if these are dumb questions be easy on me lol:
45thparallelc10s is offline   Reply With Quote
Old 10-26-2018, 05:00 AM   #2
my kids toy
Re: ls swap
Your are leaving out a bunch of info like what engine it is and you might want to post this in the lsx section, if it is a truck vortec then you will need to swap the oil pan but you should ask that question with porterbuilt, probably not to many folks here are using that set up, I used a Cadillac oil pan, I do not think any harness plugs into a factory harness
my kids toy is offline   Reply With Quote
Old 10-26-2018, 10:18 AM   #3
Custom 68
Custom 68's Avatar
Re: ls swap
Welcome, The harness is standalone meaning you need to provide power (key on and key off) and a ground. There are a few other wires you will need but you will need to splice into your factory harness. You will need a brake (on/off) switch.
There really is not much you will need to get from your factory harness. They really work independent.
We will need some more info but I used a camaro pan for my swap. If you are going from a truck motor you will need the sump line and baffles as well. There are some aftermarket that might work.
Look around in this spot on the forum and you will find tons of info. This has been done several times.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-27-2018, 01:57 PM   #4
45thparallelc10s
Re: ls swap
thanks a lot dave!
Old 10-29-2018, 08:01 AM   #5
DjS71
Re: ls swap
If i remember correctly, I saw Modern Vintage Systems on instagram state that they would do an LS harness wired in to a American Autowire Classic update harness if that is what you're looking for.
Check with PB on the pan, CTS-V will probably work but they ought to know.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
