Old 10-26-2018, 03:58 PM   #1
ThreeQuarter
ThreeQuarter's Avatar
WTB TH400 Speedo Drive Gear: 7 or 8 Tooth
I have a 3.07 (3.08?) rear gear ratio so my transmission builder needs a 7- or 8-tooth drive gear for my TH400 speedometer. This is the gear that goes on the shaft. Not sure if it matters but this is a short tail shaft.
Builder says his supplier has told him the part is obsolete, no new ones to be had.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 10-26-2018, 05:14 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: WTB TH400 Speedo Drive Gear: 7 or 8 Tooth
Can't help with finding one but what size tire do you have? 15/35 or 15/36 for a 26" tire.
17/34 for 31" tires.
http://www.tciauto.com/tc/speedometer-gear-calculator/
Make sure to scroll down to TH400 -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 10-26-2018, 07:01 PM   #3
ThreeQuarter
He didn’t pass along what his calculations are, but here’s what I’m figuring:
Tire size 27.7”
Gear ratio 3.076
He must be thinking 8/18 but it looks like 17/38 will be even closer.
I assume I can ignore that some driven gears in the TH400 table are labeled (truck)? Is that just showing OE, and not an indicator that I should limit my selection to only those gears?
Ben
