Old 10-26-2018, 04:43 PM   #1
macs61
power steering
Hi guys need help, am rebuilding my 61 c10. The project i am working on is installing power steering. My truck has 2 holes in firewall one for brake and one for clutch with brace for dash right in the middle of the 2 holes. Trying to figure out how to mount new brake booster truck converted to auto trans . Any help would be appreciated thanks Walter
macs61 is offline   Reply With Quote
Old 10-26-2018, 07:24 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: power steering
Talk to Captn Fab! He makes an adapter for our trucks, he has one to fit your application!
Oh, and welcome to the forum!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-27-2018, 01:19 AM   #3
Captainfab
60-66 Nut
Re: power steering
This is what you need.
http://www.67-72chevytrucks.com/vboa...49#post3479149
I do make a power steering adapter plate kit for the '60-'62 frames also.
Old 10-27-2018, 04:27 PM   #4
macs61
Re: power steering
Thanks captain fab i need what ever it will take to do the conversion , let me know what i need and i will purchace it from you. Thanks guys for your help Walter.
Old 10-27-2018, 07:53 PM   #5
macs61
Re: power steering
Thanks for your help i need what ever it takes to fit power brakes to my 61, send me an invoice, we can go through pay pal. macs61
Old 10-27-2018, 11:55 PM   #6
Captainfab
60-66 Nut
Re: power steering
I'll send you a PM.
Old 10-28-2018, 02:11 PM   #7
macs61
Re: power steering
Ordered part today thank you for your help.
Old 11-01-2018, 06:54 PM   #8
macs61
Re: power steering
Thanks Captain Fab received power steering bracket today great workmanship.I purchased a 8 inch dual diaphragm with universal brake pedal said to fit a 61 from ccp. There is no way the brake pedal assembly will fit against firewall with dash brace do you or any one on the forum have any solutions .
Old 11-01-2018, 07:00 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: power steering
Old 11-01-2018, 11:55 PM   #10
Captainfab
60-66 Nut
Re: power steering
I'm confused. You started out asking about power steering, and then changed to asking about mounting a brake booster. I sold and shipped you a brake booster bracket for your truck. I don't know what this 'brace' is in between the 2 holes in the firewall. I have never seen such a thing on a '60-'62 truck. I'm thinking a previous owner may have installed it for some reason. Or are you referring to the pedal bracket on the inside of the cab?
Old 11-02-2018, 11:43 AM   #11
macs61
Re: power steering
Sorry for the mistake I am installing power brakes and your part is what i need. What i am trying to do on the inside of the cab is fit a different brake pedal as I have removed the old pedal assembly. The brace i am talking about is the support from above the steering collum to the firewall, It restricts fitting a different pedal . Got a bad dose of the flue brain is not working.
