Old 03-31-2002, 12:29 AM   #1
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Question What is right
Someone told me I should put a vent on my valve cover. Someone else said that I shouldn't. They said you don't want to use a vent when you have a pcv valve. I don't know anything about this. What is right? Someone else suggested that the proper way is to put pcv valve on one valve cover at back of motor and vent on other valve cover at front of motor. Or does any of this even matter. Thanks a lot.
Mitzki5
69 GMC Shortbed
Central, Illinois
Mitzki5
No longer have an old truck! But always looking for another one!
Mitzki5 is offline   Reply With Quote
Old 03-31-2002, 12:32 AM   #2
69 longhorn
Post
PCV on on cover,& a vent on the other cover. I would prefer to have the PCV at the front.......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-31-2002, 12:52 AM   #3
hobby67stepside
Post
The PCV is the vent "Postive Crankcase Ventilation" valve if I remember correctly. No other vent wanted. That was the purpose of it - recycle crankcase fumes thru the carb.
  • '05 2500 HD Silverado 6.0 liter
    '97 2500 4X4 454 eng
    '92 2500 4X4 350 eng
    '78 K20 4X4 400 eng
    '70 Boss 302 (owner for 27 years)
    '57 Ford shortbox 383 stroker TH350 tranny
    '23 T-bucket (built in '78)
    '02 Explorer
    '67 C-10 short step
NW Iowa
hobby67stepside is offline   Reply With Quote
Old 03-31-2002, 01:11 AM   #4
69 longhorn
Post
It needs a vent on the opposite cover.....if you look at the stock setup,it has a PCV in 1 cover,& the other cover has a tube running to the breather. On the older than 68 setups,the PCV screwed into the carb,& had a hose to the rear of the block.....& had a vented cap on the fill tube.......69 longhorn.
Old 03-31-2002, 01:33 AM   #5
chevymad
Post
It needs a vent in one cover to let air into the crankcase. Otherwise the pcv will suck a hard vacuum in the engine at times.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 03-31-2002, 09:20 AM   #6
racedvl
racedvl's Avatar
Cool
If ya look, I have a breather on the drivers side. Near the upper rad. hose. Then I have a hose running from the base of my carb, to the PCV valve on the passenger side. That's how I have mine set up.
http://hometown.aol.com/racedvl/racedvl69index.html
Woodstock,IL.northwest of Chicago
It's not what you buy, it's what you build!!
I did not climb to the top of the food chain, to become a vegetarian.
For some pics of my truck.
[This message has been edited by racedvl (edited March 31, 2002).]
racedvl is offline   Reply With Quote
Old 03-31-2002, 11:24 AM   #7
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
you need a vent with the pcv valve, or you're going to draw too much vacuum in the crankcase. If the valve covers were not designed for the pcv, you may want to find some that are, as you need an oil deflector under the pcv valve to prevent sucking oil up into the carb.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
