Old 10-27-2018, 06:00 PM   #1
aotte1
66 Vs 67 C20 Track Bar Bushing Difference
How is a C20 track bar bushing for a 1966 and 1967 different?
aotte1 is offline   Reply With Quote
Old 10-27-2018, 11:53 PM   #2
Captainfab
60-66 Nut
Re: 66 Vs 67 C20 Track Bar Bushing Difference
As far as I know they should be the same '63-'72 with the Eaton HO52/72. I think the Dana 60 has a stud in the center section like the '65-'72 12 bolts. I would have to go look tomorrow to verify that.
Old 10-28-2018, 03:53 AM   #3
aotte1
John,
Thanks for checking if track bar bushings are the same size for C20 66’ vs 67’ style.
Thanks,
Les
Old 10-29-2018, 11:37 PM   #4
Captainfab
60-66 Nut
The '67-'72 C20's with the Dana 60 differential do use the stud mounted in the center section casting just as the '65-'72 12 bolts do. Consequently the panhard bar is shorter and uses a different bushing than the panhard bar for the Eaton HO52/72.
Old 10-30-2018, 02:43 AM   #5
aotte1
John,
Thanks,
For the Eaton HO52/72 axles, are 66 and 67 track bar bushings the same, if you can check.
Thanks,
Les
Old 10-31-2018, 12:12 AM   #6
Captainfab
60-66 Nut
I do not have any '67-'72 C20's to be able to check first hand. I don't know why the '67-'62 would be any different than the '60-'66. According to Classic Parts, the bushings are the same '60-'72.
https://www.classicparts.com/1960-72...info/74%2D852/
Old 10-31-2018, 12:31 AM   #7
aotte1
John,
Just ordered a set, will report how they work out.
Thanks,
Les
Old 11-02-2018, 10:15 AM   #8
60-66
60-66's Avatar
Les , have you looked up the GM part number for these ? Group 5.417 part number 3829519 shows 1963-1971 C20 . Theres a pair on ebay right now.
https://www.ebay.com/itm/NOS-75-76-7...5:pf:0&vxp=mtr
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-03-2018, 12:14 AM   #9
aotte1
John,
Thanks,
Got them.
My 66’ C 20 will get them. Photo, Apple issue.
Do you know of any nos C20 Eaton HO rear hubs.
Les
