![]() Join Date: Feb 2009
BBC motor mount perches have slotted holes. Positioning?
Rebuilding a 71 BBC 400TH. The top of the engine perch and the engine cross member have slotted holes, giving 3/8" play front to back. If I knew better I'd have marked them, but I didn't.
Anyone know how they're supposed to be positioned, or ideas where I should start? I figure right in the center, but can't say for sure. Never done this before, but I suppose the worst case scenario is I leave everything loose, and adjust them square in position for the transmission mount. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: BBC motor mount perches have slotted holes. Positioning?
Probably a dumb question. I think that's exactly what you do in this case, line up the transmission and torque everything down.
Now comes the question, where do you line up the transmission?
Post Whore
![]() Join Date: Feb 2016
The transmission will be fine, as the yoke will take up any thing the slots will allow. Remember these were designed to allow assembly quickly without a bunch of alignment steps by people with hangovers.
![]() Most of the time the front slots will be in different spots due to the loose tolerances in the motor mounts. You will have to have the bolts all loose when you set the engine (so you can get the bolts that come up through the stands started. Best to start the transmission bolts and float the engine while you get all the rest of the bolts started. ) then check the tail shaft of the transmission is centered (+/-1/8") Of a bigger concern is checking the drive line angles, especially if you have altered the vehicle's height. I had to put a spacer under my transmission mount to get things in line. It you have a K model you may find that putting the mounts as far forward as possible to start may give you bit more clearance behind the distributor when you're done.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
That's what I would do. Bolt it all together loosely then push it around until it all seems to be lined up then torque it all down.
Tailshaft centered!
Is it supposed to be centered? |
Post Whore
The transmission mounts usually have 3/8" or larger slots in them. By centering the the tail shaft you help eliminate one point of vibration. Driveshaft alignment needs to be done not only vertically but horizontally for smooth ride. If the engine and transmission are in the frame at an excessive angle (4 degrees) it may give you a vibration that will be difficult to locate later. A simple check with a tape measure is all that is needed.
#8 | |||
For what it's worth, picture of the transmission spacers. Quote:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-28-2018 at 11:39 AM. |
#9 | |
Post Whore
For the most part the slop in the front mounts is fore and aft with not a lot of play side to side. But for peace of mind it is another simple check with a tape measure that may reveal a hidden problem.
Post Whore
The play is in the bolt holes which are slotted not to mention any slop in 45+ year old cross member mounting holes. And with my Monday/Friday built truck I didn't even assume the cross member was perfectly centered between frame rails.
#12 | |
Post Whore
Starting with the spacers is fine. You have to start some where. Although my guess is with a one piece drive shaft you won't need them to match the pinion angle. But that really can't be determined until the truck is fully assembled and at ride height.
#13 |
What I’m trying to get at is everybody assumes the tailshaft needs to be centered.
That’s not always correct. Usually the centreline of the motor is parallel to the frame. The motor could be offset an inch or more to the passenger side. The offset is usually there to compensate for the pinion offset in the rearend. When people assume the tailshaft should be centered they can induce some strange hard to find vibrations. |
#14 | |
Post Whore
There certainly are some trucks that have this combination and have vibration issues where others don't. Where the axle is located side to side may be heart of the matter. Some sort laser alignment may be the solution.
#15 |
![]() Join Date: Oct 2009
Great discussion with geez and HO! Yes, "parallel" is the key word (and NOT in line). "A" is bad, "B" is good. The engine offset isn't necessarily a compensation for the pinion offset, it's by design to provide proper phasing of the driveline. Also, as HO455 was pointing out, when a center bearing is used, note the phasing takes place on the rear driveshaft.
#16 |
Tony here's a good article on driveline phasing, most of which has been covered and am sure you're already aware. Pertains more to a custom build rather than a resto, but good info nonetheless (and the source of the 1st picture above).
https://jniolon.classicpickup.com/dr...nephasing.html Last edited by jocko; 10-28-2018 at 01:12 PM. |
#17 | |
I found the holes in the transmission cross member with perhaps 1/16" play, but they're perfectly round. I also measured 14.3/8" from the top front corners of the carrier cross member (still has the rivets) to the top rear corners of the transmission cross member. On a side, they missed 3-4 rivets on this truck, smoking their lunch and all. Two of those were for transmission cross member pieces. Surprisingly, it had just shifted a pinch. Almost everything I measure now ends in 3/8", it's starting to freak me out ![]() My truck is an odd duck 71 SWB, 2WD, with rear leaf springs. Strikes me as a Chevy with 2wd GMC suspension ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-28-2018 at 10:10 PM. |
#18 | |
Great to know on that drive shaft. I may start with one spacer. The front will be down approx. 2.5", and the rear down 4". I am running HEI. I think I make-out an indent in the frame where one of the engine perches was mounted. The HEI had nice clearance before I tore her down.
#19 | |
#20 |
Turns out I have a picture, since relabeled. An engine perch is clearly shown on zoom. The perches were set forward approx. 1/8" an inch, and the frame has very small indentations to support it
![]() Doesn't mean it's factory. Buddy and I R&R'd the rebuilt engine in 1993. I don't know if we removed or adjusted the perches. I do know it worked or close. There was no apparent vibration and the HEI had nice clearance. That said, still doesn't mean the angle was perfect. Got to thinking about it, haven't viewed your link yet Jocko. It would be miserable to measure from the frame to the engine, because the frame rails aren't a right angle. The patience required is probably beyond me ![]() But then I thought, if I measure the rear corners and center of the engine/trans vertically to say the axle, a square cross member and/or a random horizontal square line, that should confirm parallel. I suppose you could even run a string line down the center of the frame from the front cross member to the rear. If the center of the engine and trans are the same distance from the string line front to back etc., strikes me the engine and trans are positioned parallel the frame. I may do that as well. Thanks a bunch. Now I have to figure out the drive-shaft and trans. shims, if any............fun ![]() ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-29-2018 at 05:33 PM. |
