Old 10-27-2018, 10:01 PM   #1
xKid4x4s
xKid4x4s's Avatar
Question Need help naming a sensor on the shift cable.
Hey everyone, I have a 2000 (obs) k3500 w/4l80e transmission.
I am replacing my shift cable, and noticed a small switch/sensor right under the dash, attached to the same spot as the shift cable is, and therefore It moves in sync with the shift cable.
I have issues with my PRNDL Lights not working, and I think this is the culprit. I cant find out what its called though so I can buy one! Its not the range switch, I replaced the one on the tranny that the other end of the cable attaches to already and have also replaced the gauge cluster, no luck. Could this be the issue, and what exactly is "this".
thanks!
1967 Chevrolet Biscayne
1968 Chevrolet C10
1990 Chevrolet K1500
1999 Chevrolet 1500
2000 Chevrolet K3500
xKid4x4s is offline   Reply With Quote
Old 10-31-2018, 08:34 AM   #2
sntrym95
sntrym95's Avatar
Re: Need help naming a sensor on the shift cable.
Do you mean this piece? https://www.summitracing.com/oh/part...5841/overview/
This is the shift lockout that requires you to put your foot on the brake to shift out of park.
Mike
sntrym95 is offline   Reply With Quote
Old 10-31-2018, 02:01 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
There is nothing in the column that affects the PRND321 display.
The part on the column is what GM calls BTSI(Brake Transmission Shift Interlock).
If there was a problem with that, you wouldn't be able to move your shifter out of park.
I will get a wiring diagram for the PRND321 display. I may need to post it from my phone.
95 S_Trucker is offline   Reply With Quote
Old 10-31-2018, 07:04 PM   #4
xKid4x4s
xKid4x4s's Avatar
Thumbs up Re: Need help naming a sensor on the shift cable.
Yes! Thank you both for the helpful answers.
1968 Chevrolet C10
1999 Chevrolet 1500
Old 11-01-2018, 07:29 AM   #5
95 S_Trucker
Finally got a chance to post the diagram:
