10-28-2018, 12:09 PM | #1 |
Bedside tool box with no key
I have looked over the threads and seen this brought up before but didn't find any answers yet.
I have a locked bedside toolbox with no key. I thought about drilling it out but the locks are not apparently available for replacement. Any experience would be appreciated. My door is very far gone with rust and I'm sure I will be in need of one and at least one hinge from what I can tell with door still closed. This is on a very original 72 Sierra Grande that I will be doing a complete restoration on and a hate to loose that option as the truck is loaded with options. |
10-28-2018, 12:22 PM | #2 |
Re: Bedside tool box with no key
If you haven't done so, recommend PM member LockDoc.
10-28-2018, 08:13 PM | #3 |
Moderator
There are various styles of lockbox locks available...try looking on amazon first to check if the style is available...
lockdoc may have better suggestions, but it may be a drill it out and look for replacement... Some of these locks are retained by a simple thin steel wave plate that can be bypassed by jemmying on the lock itself.... Post a pic of the lock for us to review...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-28-2018, 09:23 PM | #4 |
if there is a number that you can see on the lock core , that would be the key code and a locksmith can cut you a key by that code.
10-29-2018, 06:37 AM | #5 |
A good locksmith should be able to pick it. Once it is open, you should be able to remove the lock cylinder and have the locksmith make up a new key for it.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
10-29-2018, 08:46 AM | #6 |
X2 ,quite easy.
10-29-2018, 10:02 AM | #7 | ||
The Older Generation
In the picture the lock is in the unlocked position. When locked the tab turns and blocks the lock bolt so it can't be retracted when the handle is pulled. Quote:
See above.... LockDoc
10-29-2018, 10:12 AM | #8 |
If the door is gone anyway, maybe it makes sense to cut the door open to try and save the lock assembly. Just a thought.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
10-29-2018, 01:54 PM | #9 |
Great advice....I was thinking the same thing
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
10-30-2018, 08:31 AM | #10 |
Thanks LockDoc. That's what I needed to know.
Tdangle you have a good point. I believe that would be the best angle to take. Try and save the latch and lock and replace the door. The bottom of the door is badly deteriorated with rust so I can probably just cut around the hinges. |
10-30-2018, 08:33 AM | #11 |
062500hd, if you have access to a new setup pm me. Thanks
10-31-2018, 12:00 AM | #12 |
Not to hijack this thread, but is it possible to have all locks using only 1 key? I have the original key for the toolbox, a new square head key for the ignition and new round head keys for the door locks.
10-31-2018, 12:19 AM | #13 | |
I have a 71 with different keys for the ignition and door locks. This 72 has the same key for the ignition and door locks but does not work for toolbox. What I have read from the different threads, some of the toolbox keys are the same as ignition and others aren't. |
10-31-2018, 09:37 AM | #14 | |
PM sent. LockDoc
11-04-2018, 11:42 PM | #15 |
Since the bed side tool box liner is fiberglass you could drill a hole on the bottom or the side and use a large screw driver or pick to knock the clip out to release the lock cylinder. just put pop in a hole plug once you're done. just a idea.
