Old 11-19-2003, 02:14 AM   #1
ocbaud
Garage Queen Material
new torque conveter needed with new flywheel?
since my engine will be a 85-below block, i'll need a different flywheel.
the 86' flywheel was weird and i cant use that again. since i'm having to get an older style flywheel, do i have to get a new torque conveter or will the current, stock one hook up fine?
ocbaud is offline   Reply With Quote
Old 11-19-2003, 02:27 AM   #2
low 84
low 84's Avatar
you want a higher stall one anyways
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 11-19-2003, 02:29 AM   #3
ocbaud
i'm getting a higher stall one anyways
just wondering if the old one would bolt up
Old 11-19-2003, 02:43 AM   #4
1FaastC10
1FaastC10's Avatar
what does it matter if you're getting a new one anyways? but yes, it will bolt up.
1FaastC10 is offline   Reply With Quote
