72 Cheyenne
close call tonight
man, I'm glad I was low on gas! I left work tonight and went to the gas station instead of getting right on to the freeway like I usually do and on the way out of the gas station I heard this strange noise so I pull over a couple of blocks away and crawled under and saw that my carrier bearing housing, not the bearing itself but the metal bracket that holds it had broken loose from the frame cross beam.
If I had hit the freeway it would have been bad! anybody ever had a drive shaft come apart at high speeds? |
Designated A-hole!
Glad you found it before you did an endo!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I was at the dragstrip one time & saw a driveshaft break. It dug in at the front & "pole vaulted" (close eyes & use your imagination here) the rearend of the Nova up & did all kinds of nastyness. Keep your u-joints & carrier bearing in tip-top shape!
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Try spinnin 4 rear tars
My friend's truck did the same thing. Front u-joint gave up on its end of the deal and the drive shaft starting plowing for corn. The rear bucked a bit. Luckily it didn't tear anything up. We just took it out and threw it in four wheel and went on our marry way. I didn't climb under there to look, but it had a slip yoke. It tried to commit suicide a little ways down the road, so we had to stop to get it, and then hurry back home before all the lube drained out. Stinkin slip yokes!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
My other Love
didn't you have a problem with your steady bearing before?
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Member since 2000
wow, close call. I've seen a drive shaft come out before. just swung around alot but if it broke off who knows what could of happen to the truck and other drivers.
I know how you feel I had the exact same thing happen on my 69 the carrier bearing let loose and beat the daylights out of the frame bent the drive shaft and broke the transmission case, good thing it was still the factory three sp
PR Too many projects, not enough time! 72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold! 69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam. 78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's 77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs |
user # 2756
![]() Join Date: Jun 2001
A friend of mine had his front driveshaft come off on the highway on his 79 f150. It flopped around and damaged the oil pan and brake lines. Since it was lifted it would not make it to the road. He had a tree fall on the truck during Isabel I believe it was a total lost.
Someone had locked his hubs in a mall parking lot, he had felt a vibration but kept on going and bam!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
One good reason to get a one piece shaft, it would just drop to the frame cross member if it broke.
i had that break on my truck twice, broke the band around the carrier bearing not the bearing. never even made much noise though, just layed in the frame till i noticed it. one piece now.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
Back from the Dead
I had my carrierbearing bracket break too! Did yours make a strange "clicking" type noise too? I drove for a while wondering if my brakes were hanging up, until i noticed when i got home that it was barely hanging there. I also had a U-Joint cap fall off while i was in town, scared the crap outta me!
The only Carb that matters to me is the one under my hood! Salem, Oregon |
72 Cheyenne
it didn't make any noise until it came completely loose and then bang bang bang! I took it to a friend of mine who welded it back with some supports, all good now.
#13 |
Life is Good !
did that once and it scared the sh!t out of me !
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
#14 |
Life, Be In It.....
![]() Join Date: Oct 2003
Now that is a close call.
