Trouble with hydro boost install
I have 1970 C20, disc brake conversion to 73+ parts, new calibers, new master cylinder, used proportion valve and an Astro van hydro boost unit.
I turn on the truck and the brake pedal sinks by an inch or two. I press the pedal and it moves maybe an inch or two. I’m getting no fluid to the calibers or the proportion valve. Before I finished installing the master cylinder, in my haste to hear the motor run I shot the rod out of the hydro boost unit. I tap the cylinder back in and put the rod and spring back in then I installed the master cylinder. How much movement should I have from my brake pedal? Could my master cylinder be locked up or the push rod not long enough? Thanks |
Re: Trouble with hydro boost install
Did you bench bleed the master cylinder?
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
No I did not.
