Old 10-30-2018, 05:23 PM   #1
67GMCcampercruiser
Rochester 1 barrel carburetor leak
I put a carb kit in this Rochester 1 barrel carburetor and it's leaking around the gasket which seals the 2 halves. Is there some type of gasket maker silicone stuff that would stop the leak?
67GMCcampercruiser is offline   Reply With Quote
Old 10-30-2018, 06:57 PM   #2
geezer#99
geezer#99's Avatar
Re: Rochester 1 barrel carburetor leak
Lower the float level.
geezer#99 is online now   Reply With Quote
Old 10-30-2018, 07:40 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Bam! Done!
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-30-2018, 07:56 PM   #4
67GMCcampercruiser
Well that would be easy enough. I'll try it. Thanks
Old 10-31-2018, 09:39 PM   #5
Jason Banks
Jason Banks's Avatar
Are you guys serious? Is it as simple as that? Mine leaks out the top parts seal and I have a rebuild unit that doesn't run very good that came with a double gasket there...but I didn't leave it on long enough to see if it leaked also. I just figured my gaskets were cheap...
Jason Banks is offline   Reply With Quote
Old 10-31-2018, 09:42 PM   #6
geezer#99
geezer#99's Avatar
Just a logical thing to do!
Old 10-31-2018, 10:03 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Indeed! Double gaskets is an ate-up solution to a leak, if the float level is too high. That will change the float level, but also the metering rod calibration. Who rebuilt that carb?
~Steven
Simi Valley, CA
Old 10-31-2018, 10:41 PM   #8
jabborabbo
jabborabbo's Avatar
You should also make sure that the bowl and horn flanges aren’t warped from too much tightening over the years...old Rochester B carbs are known to have that problem...and don’t just flatten them on emery paper on glass...there is a thin sealing ring that you’ll sand off.
These guys were very helpful when I rebuilt mine:
https://www.carburetor-parts.com/Roc...03_p_2743.html
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 11-01-2018, 10:04 AM   #9
68panelman
68panelman's Avatar
I purchased a new rebuild kit from Mike's, but have yet to install on my 67's B model Roch. Mine is very temperamental when it does leak, usually it's seasonal and hasn't leaked in the past year, yea, strange, hence the carb kit remains in the bag, in the glove box.
68panelman is offline   Reply With Quote
