10-30-2018, 10:50 PM | #1 |
Thinking about flipping my rear axle.
I have. 79 C10. I need to do some research but i lowered the back i think about 4”. As they all say. Not enough. I have shackles and brackets on there. I have a bell tech drop on it. What do i need to do to flip it? I am not going to notch the frame.
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
10-30-2018, 11:03 PM | #2 |
Re: Thinking about flipping my rear axle.
Flip kit is just a couple of brackets. You might want a set of lowered shocks or shock re-locators. Also, if you keep the shackles and hangers, you will need to remove the axle bump stops.
You wont actually "flip" the rear end. The kit just allows you to mount the leaf springs under the axle tube. The flip kit alone is good for about a 5 inch drop in the rear. |
10-31-2018, 07:30 AM | #3 |
10-31-2018, 02:59 PM | #4 | |
10-31-2018, 06:43 PM | #5 | |
<6 leafs usually yield 6" of drop. >6 leafs will yield more than 6" of drop. Also, if you already have shackles, hangers, or some other form of drop part, you'll need the factory parts (@ least the front hangers) or the drop will be even greater.
10-31-2018, 09:33 PM | #6 |
I also want to do the axle flip, but want to remove a leaf or two out of the 8
there are now. Hoping to soften up the rear end, less truck like. Don't have lots of horsepower or a hauling a load, just a cruiser. Getting mixed responses. |
11-01-2018, 07:42 AM | #7 | |
11-01-2018, 10:23 AM | #8 |
An option is to find someone w/a stock height truck that wants a milder drop than you. Make a deal for your stuff & include their stock brackets as part of the price tag. Or.... Hit up the classifieds for someone parting out a C10 w/the stuff you need to achieve your desired drop.
