Old 10-30-2018, 11:30 PM   #1
DKSpringer
Spark Plug Lengths - shorty's
Read lots of conflicting info on forums from past posts, so I thought I would share some details. I have some cheap Chinese headers, and they don't have the best plug clearance. Here is a photo of the different length spark plugs commonly mentioned for small block Chevys. We have:
ACDelco 41-905
Autolite 145
NGK YR5
Champion RV92YC
Accel header plugs 0576S
Accel are the shortest, Champion are not far behind at a lower cost.
Hope this helps someone!
DKSpringer is offline   Reply With Quote
Old 10-31-2018, 12:55 AM   #2
ilnvyb360
ilnvyb360's Avatar
Re: Spark Plug Lengths - shorty's
Thanks for the info!
ilnvyb360 is offline   Reply With Quote
Old 11-04-2018, 11:32 AM   #3
Axle
Axle's Avatar
A Denso u11 is just shy of 2.25" from taper to end of plug. Can you measure any one of the ones you got pictured? Just to be able to reference to what the reader has on hand.
Alex.
Axle is offline   Reply With Quote
Old 11-04-2018, 12:57 PM   #4
DKSpringer
I'm out of town for a while, but here's a thread with some reference.
http://nastyz28.com/threads/spark-plug-length.60539/
I believe the UR5 is the same as my YR5 at 2.072"
Old 11-04-2018, 07:41 PM   #5
Dead Parrot
Which, if any, fit your header setup?
Dead Parrot is offline   Reply With Quote
Old 11-04-2018, 10:48 PM   #6
DKSpringer
The NGK/Champion fit everywhere but #5. It needed Accel. You can get a pretty good deal on the Accels at Advance Auto with a 25% off deal. I also have the fiberglass spark plug wire protectors.
Old 11-05-2018, 09:23 AM   #7
I used the accel's on my last 2 trucks with V8s and headers, They made a huge difference in clearance. Neither engine had much mods and they ran very well also for my situation.
Old 11-05-2018, 11:07 PM   #8
MikeB
MikeB's Avatar
And here's a picture comparing two non-tapered seat plugs for older heads and aftermarket aluminum heads. Not just shorter, but smaller body diameter and wrench size, too. Great for keeping plug boots away from header tubes. That's an NGK on the left, but Bosch and others also make plugs in that same size (called "ISO").
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-06-2018, 06:13 PM   #9
ilnvyb360
ilnvyb360's Avatar
MikeB,
Can you share the NGK part number? I’m seeing BKR5 and an 11 under that but can’t make out the rest.
Thanks!
B
Old 11-06-2018, 06:32 PM   #10
MikeB
MikeB's Avatar
They are BKR5ES
B = 14mm thread
K = hex size 5/8"
R = resistor
5 = heat range (comparable to AC 44 or 45, as I recall)
ES = standard 3/4" reach
Got them 10-12 years ago, so their part number scheme may have changed since then.
I have an NGK chart that shows "11" means the gap is 1.1 mm or .044". I guess that refers to the out of box gap.
Mike
Old 11-06-2018, 07:52 PM   #11
ilnvyb360
ilnvyb360's Avatar
Great info! Thanks MikeB!!
Old 11-07-2018, 10:48 AM   #12
MikeB
MikeB's Avatar
Here's a link to the NGK chart:
https://rb30det.com/wp-content/uploa...7/ngkchart.jpg
Mike
