Old 10-31-2018, 07:25 PM   #1
Kustomkampe
Laminated circuit plug question
I’m getting no juice to the plug wires 1&12 that feed into the laminated circuit and in turn feed the amp meter/ voltmeter can somebody tell me where they originate? Alternator, coil? I don’t know thanks for your help
Kustomkampe is offline   Reply With Quote
Old 10-31-2018, 08:20 PM   #2
ray_mcavoy
Re: Laminated circuit plug question
The wire from pin #1 originates at the truck's main power distribution point, which is a multi-wire factory splice located inside the wiring harness near the voltage regulator. The wire from pin #12 originates at the junction block on the passenger side fender near the battery.
Both of these wires are protected by 4 Amp inline fuses located near the origination points.
The factory fuse holders (if still in place) look like this:
ray_mcavoy is offline   Reply With Quote
Old 11-01-2018, 08:45 AM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
This usually the cause of a non functioning amp gauge.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-02-2018, 12:26 AM   #4
Kustomkampe
Sure enough. I love when it’s only blown fuses! I’ve got the factory amp meter working now. It’s the little things. Thanks for your help and picture of the factory fuse fixture.
