Old 11-01-2018, 01:44 PM   #1
trkfrmr
Dana 60 emergency brake cables
Does anyone know a source for rear cables for my Dana 60 with rear leaf spring 71 GMC C20?Thanks.
trkfrmr is offline   Reply With Quote
Old 11-01-2018, 02:33 PM   #2
Killer Bee
Killer Bee's Avatar
Re: Dana 60 emergency brake cables
Inline Tube referenced around the forum quite often..
may be able to search for some threads referencing your application..
https://www.inlinetube.com/pages/pro...11159114828525
or give them a call to see what they offer..
good luck!
Old 11-02-2018, 09:35 AM   #3
DANTIP
DANTIP's Avatar
I had Inline Tube make a pair for me this past summer. I had them lengthen the cable they offer by 2". The standard cable is for the "Corporate" rear and will be short if used on the Dana. If you PM me, I'll send you my order number.
Dan
DANTIP is offline   Reply With Quote
Old 11-02-2018, 09:42 AM   #4
jocko
jocko's Avatar
I had the same problem, 71 C20 D60. I ordered a set from Inline Tube, they had a part number for them, then they cancelled the order on their end - no longer carried the part. This was about 7-8 years ago, and I think the solution was to have them make an original set for me, as others have noted. I'd give them a call, I've been pretty happy with their customer service. Be very specific about the application and, if you have old ones, they may ask for them as a template, may not. I think I had to send them mine. (EDIT: just saw Dan's post - that sounds about like what they did for mine, they may not need you to send yours in as a template any more, like I said that was quite a few years ago).
Old 11-06-2018, 05:48 PM   #5
trkfrmr
Thanks for all the replies!
Old 11-15-2018, 08:37 AM   #6
DANTIP
DANTIP's Avatar
Dan
I confirmed with the retired Dana mechanic that installed my cables that the Inline-Tube C-20 cables with 2" added were perfect. If anyone needs them, Inline can reference my order number (#S202740) for details.
Dan
