Old 11-02-2018, 03:05 PM   #1
kajf9491
kajf9491's Avatar
Rally Wheel Lug Nuts
I need some help. I need to get my wheels and tires off, but cannot figure out what's going on with my lug nuts. Has anyone seen these before and does anyone have any suggestions on how to remove them? I 17mm socket fits on them but my 17mm tire iron doesn't (no idea how that works). Do these require a special keyed socket?
kajf9491 is offline   Reply With Quote
Old 11-02-2018, 03:08 PM   #2
Indychus
Indychus's Avatar
Re: Rally Wheel Lug Nuts
Those are spline drive and do require a special socket. If you try to remove them with a normal socket they'll round off and you'll have a bad time.
Indychus is offline   Reply With Quote
Old 11-02-2018, 03:20 PM   #3
kajf9491
kajf9491's Avatar
Thanks Indychus! Do you have anywhere you suggest that I may be able to pick up a spline socket? Looking around online and I'm not seeing them as being carried at the local auto part stores. Will something like this socket from Lowes work?
https://www.lowes.com/pd/Kobalt-Univ...ket/1000073671
Old 11-02-2018, 03:22 PM   #4
Indychus
Indychus's Avatar
Not sure what size you'll need, but Jegs has them.
https://www.jegs.com/i/McGard/671/65300/10002/-1
Old 11-02-2018, 03:23 PM   #5
Indychus
Indychus's Avatar
Old 11-05-2018, 03:48 AM   #6
TrkEnvy
The socket you are referring to is called a spline key. Any tire chain store should be able to let you use a spline key that fits that lug set, however they may make you buy a new spline lug nut kit to get to keep a key as I don’t know if they sell just the key.
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline   Reply With Quote
