11-03-2018, 12:23 PM | #1 |
C60 Grill questions
I've searched for a few weeks on this with little to no luck. So I will be putting a C60 grill on my C10. Im curious to what people did to move the Chevrolet to the middle of the grill? Did you just make brackets, or cut the tabs off the top and weld them to the bottom?
Any help would be great! This will be my winter project for ol' Willy. Thanks everyone. *idea of what I'm talking about. I believe this is Maggies truck (if not sorry) https://goo.gl/images/ie2zdc Not sure who's truck this is: https://goo.gl/images/ResjGT |
11-03-2018, 01:05 PM | #2 |
Re: C60 Grill questions
I too have added the C60 grill to my truck....What I did was remove the center tab, then I welded 2 tabs...one in the center and two near the ends and welded bolts onto the center section so that it can be removed when it goes to get plated....Here is a picture of mine mocked up before tabs were put in. The headlight buckets from your old grille will need to be put into this one and it bolts right up with no issues
11-03-2018, 03:31 PM | #3 |
Thanks for the reply and it looks great. Did you use any specific metal for the tabs you added? Grill and truck look good!
