Old 11-03-2018, 07:01 PM   #1
Notch1988
Notch1988's Avatar
Setting Up a 2 Piece Driveshaft - HELP
Looking for ideas on what to do. I'm trying to get my pinion angle set so I can start welding the mounts, watts link and bag brackets on but I'm having issues. First, how do I get my angle of the last piece (center bearing to diff) if I haven't set my pinion angle? If I rotate my pinion up or down, it will change the angle of the driveshaft, thus then changing the angle I need to set the pinion, which then changes the driveshaft angle and it's just a vicious cycle.
Second, my angles seem pretty extreme. My first operating angle is good, sitting at 1.5 deg but my second is going to be in the teens, like 16 deg which will leave my 3rd angle fairly extreme too.
I've got the carrier bearing shimmed up 2 inches now and have no room to go more. The motor/tranny is already at 5.5 deg down.
The driveshaft is from the donor truck that I grabbed the LS motor/tranny from so it can be changed to a different setup if there's other options that would improve my angles.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 11-03-2018, 07:36 PM   #2
geezer#99
geezer#99's Avatar
Re: Setting Up a 2 Piece Driveshaft - HELP
Maybe this will help.
https://spicerparts.com/anglemaster/measuring-angles
Or something in this bunch.
https://www.google.com/search?tbm=is...10.26C0e2OpNX8
Old 11-04-2018, 03:37 PM   #3
Grounded63
Kick the pinion up until it is at an equal and opposite angle to the front drive shaft. You want both u joints to see the same angle, but 180° out of phase. The vehicle should be at its ride height/normal weight when its set.
Also if you have the room, i would mount the engine flatter closer to 1-3 ° down, would be more typical or preferred. That will decrease your rear u joint angles, and the stress/wear on them. Plus it will run smoother.
Grounded63 is offline   Reply With Quote
