Old 11-19-2003, 10:13 AM   #1
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Radiator bracket help! :)
Hey guys/gals.
I am upgrading to a heavy duty radiator. I need to get the bigger mounting hardware. Does anyone know if the hardware from a 454 truck will work?? I had the little tiny one on there before. Thanks for any help.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 11-19-2003, 10:50 AM   #2
Mike76251
I put a 8-core in mine and all I had to do was make the top brackets about twice as deep.
I did it with a scrap piece of steel and a mig machine.
Mike76251 is offline   Reply With Quote
Old 11-19-2003, 10:50 AM   #3
77bowtie
As far as I know And if I wrong someone will straighten me out. For our years of trucks all with a 400 or 454 engine used a 4-core radiator. A nd all other engines used a 2-core radiator. Good Luck...Jon
77bowtie is offline   Reply With Quote
Old 11-19-2003, 11:32 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Define heavy duty... I went from the stock 2 core to a 3 core in my '86, and it used all of the same hardware. If you use a 4 core, you have to change everything out like Gerardo is doing.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-19-2003, 12:09 PM   #5
LOHRTBT
LOHRTBT's Avatar
Gman!!! what do I need!?
~Dave~
Old 11-19-2003, 12:39 PM   #6
Mike76251
My 8 core was custom made by soldering two 4 cores together and adding stock-looking end caps.
I saw it on a truck at the local radiator shop and just ask the owner to build me one.
He worked there and did it for around $150.
I mainly did it so I didn't have to cut the AC off while sitting in heavy downtown traffic.
It works great.
Old 11-19-2003, 12:49 PM   #7
LOHRTBT
LOHRTBT's Avatar
8 core!!!! GDAMN man!! lol a four core is huge!! haha
~Dave~
Old 11-19-2003, 02:50 PM   #8
AirMale
AirMale's Avatar
I converted to a 4 row 2 years ago and all I did was go to my GM dealer and order the top hold down radiator brackets for a suburban with a 454cu. Don't forget the rubber cushions for the top and bottom (4). The holes should allready be on your rad support (mine were). I ordered my radiator online from someone but I think you can get it delivered in a day for $150-$175 at your door! It's huge...should hold like 3 gallons.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 11-19-2003, 04:16 PM   #9
LOHRTBT
LOHRTBT's Avatar
That is exactly what I needed to know!! thanks man!
~Dave~
Old 11-19-2003, 04:21 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
All the ones I converted didn't require changing anything. The physical size is the same, only the core has more flues.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-19-2003, 04:57 PM   #11
LOHRTBT
LOHRTBT's Avatar
Oh no....my new one is easily 2x the thickness on the sides and top as teh old one.
the old one was TINY
See below.....
~Dave~
Old 11-19-2003, 05:04 PM   #12
AirMale
AirMale's Avatar
There is a three row that will fit under the stock small block chevy rad mounts. The 4 row is massive in comparison. You could probably take the fans off and still run at 140°. I use Dex cool in mine, it's supposed to be less corrosive to gaskets and and stuff.
86 SWB 9.0 LITER
Old 11-19-2003, 09:22 PM   #13
Captkaos
Captkaos's Avatar
Actually you are looking at the wrong place. You are looking at the center top of the radiator. Look where the tank meets the flues, that doesn't change on truck versions. Look at the clip/bracket holding your radiator. (near the cap) It will have a rubber "cup" that isolates the radiator (see the rubber teat). That will be the same on your new radiator. The rubber portions sit on the radiator "flange".
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-19-2003, 10:09 PM   #14
low 84
low 84's Avatar
i did the same thing your doing dave. and my stock brackets were too small. the smaller ones just use those 2 brakets, one on each side. the 4 core ones use a top plate that covers the whole top of the radiator and holds it in. i got the top plate from chevy duty and it was like 13 bucks or something, and you need to get the new rubber deals also. and make sure you get the one for the newer trucks cause i first got one of an older ( like pre 80) truck and they are differnt and won't fit the top of our core supports.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 11-19-2003, 10:45 PM   #15
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs down
You may want to remove the dexcool and reinstall the regular anti freez.
Read this----->http://www.geocities.com/b_gillie/dexcool_problems.html
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 11-19-2003, 11:17 PM   #16
LOHRTBT
LOHRTBT's Avatar
Exactly what I am doing . thanks for the info guys!
Chris...itsway bigger...I will take picshehe.
~Dave~
Old 11-19-2003, 11:33 PM   #17
rage'nrat638
rage'nrat638's Avatar
be cool rad...w/ suburban top brackets
rage'nrat638 is offline   Reply With Quote
Old 11-20-2003, 01:28 AM   #18
Mike76251
It just looks "normal" to me now! LOL
Actually, it looks just like a diesel radiator in a military version of our trucks.
A friend did drop by one day and raised his hood, he had a 4 core and it looked real thin compared to my custom rad.
Old 11-20-2003, 02:08 AM   #19
Mike76251
Here is a pic of the 8-core (side tank view)...........can't get a shot of the two 4-core units inside.
Old 11-20-2003, 11:51 AM   #20
LOHRTBT
LOHRTBT's Avatar
I dont get it?? looks just like the one I bought. Where are the extra 4 rows at?? That is just like the big dog I bought.
~Dave~
Old 11-20-2003, 01:02 PM   #21
Mike76251
I think the side tanks are what you are looking at to judge the size of it.
Look at a standard 4-core without the side tanks attached............you see a 1 1/2" thick stack of rows.
This one has two of those 4-core rows...........one right in front of the other.
Also,look at the AC compressor in the pic, it no longer cleared the fan shroud after I put the new rad. in.....I had to trim it with a notch.
Old 11-20-2003, 03:00 PM   #22
AirMale
AirMale's Avatar
Thank's Bruce for the update on the DEX-COOL. I'm actually using the Mopar version of DEX-COOL, not sure what it's called but it's free cause my bud works at the dealership DAVE--->I have some spare brackets around for the four row rad cause I used the single top mount plate too. You may want to order that instead but are welcome to mine free.
86 SWB 9.0 LITER
Old 11-20-2003, 03:04 PM   #23
LOHRTBT
LOHRTBT's Avatar
Thanks man....I think I am going to use the new single mount plate.
That Rad that you have Mike still looks like mine all the way around lol...I will get a few pics when I get it put in.
~Dave~
Old 11-20-2003, 09:16 PM   #24
stan79chevy
stan79chevy's Avatar
i have a deisel radiator in mine
i had one of those small 2 core kind and switched to a big ass deisel one iwth transmission and oilcooleres built into it. all i had to do was switch the top plate to the kind that comes of 454 and 400's. all the holes were allready there didnt have to do any drilling
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 11-21-2003, 02:09 PM   #25
PHOENIX
Same with me. Went to 4-core from 454, with the electric fan it cools extremely fast.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
