Old 11-04-2018, 05:05 PM   #1
hotdog hound
Another broken carrier bearing
Coming back from the last car show of the season I heard a thumping noise crawled under the truck today and she has broken another carrier bearing thats 2 in 2 years. I read the threads last year and opted for the suggested bearing from NAPA only got about 250 miles out of it. The first one was from Auto Zone and lasted 50 miles. So in reading the many posts on here for this issue seems that one piece dive shafts are not recommended. I lowered the back of truck 4 inches with lowering springs and the front 2 1/2 inches with drop spindles I got no noticeable vibration all year to suggest a out of balance drive shaft(s) any recommendations for a HD carrier bearing?
Thanks for any help
hotdog hound is offline   Reply With Quote
Old 11-04-2018, 05:22 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Another broken carrier bearing
What broke? Do you have a picture?
I had one where the spotwelds that hold the plate that is threaded to mount the bearing broke off the rest. I saw someone else post here they had the same problem. I just welded mine back together and have had no problems since.
Jason Banks is offline   Reply With Quote
Old 11-04-2018, 05:26 PM   #3
Jrainman
Jrainman's Avatar
My personal experience in muti drive shaft applications that I have had when replacing a worn carrier is that making sure the drive line is perfectly balanced ,or you will experience premature carrier wear , the only way to achieve this is to have the entire drive line balanced with the new parts by a shop that has the rite eqiument to balance the entire drive line.
most people make the mistake in when replacing the carrier not marking up the multi driveline when dismantleing , throwing the drive line out of balance when reinstalling .
driveline components do wear ,and overtime because they are multi shafts and in many cases balancing can never be achieved . I found out this from my driveline specialist ,sometimes it pays to just replace it all from end to end, in the end its worth the money and agravation to leave it to the professionals .
Jrainman is offline   Reply With Quote
Old 11-04-2018, 05:49 PM   #4
Kudzupatch
Kudzupatch's Avatar
Originally Posted by hotdog hound View Post
... I lowered the back of truck 4 inches with lowering springs and the front 2 1/2 inches with drop spindles I got no noticeable vibration all year to suggest a out of balance drive shaft(s).....
This sounds like a classic issue of the driveline not being properly set up. That the angles changed after the drop and have not been corrected. Have you checked them after dropping it?
Kudzupatch is offline   Reply With Quote
Old 11-04-2018, 08:13 PM   #5
hotdog hound
Size:  22.2 KB here is the picture hope it comes through
Old 11-04-2018, 08:33 PM   #6
old51sedan
old51sedan's Avatar
I just lowered mine 4 inches in the rear, was suggested that I install shims under the axles to bring the pumpkin back up into alignment where it was originally. Also recommended to install a new adjustable panhard bar if you have coils. Do a search on the subject.
old51sedan is offline   Reply With Quote
Old 11-04-2018, 08:41 PM   #7
hotdog hound
Thanks for the responses !! ned to get pictures posted there have been a lot of changes to my truck since I bought her.
Old 11-04-2018, 09:35 PM   #8
HO455
Post Whore
HO455's Avatar
Is this a leaf or coil spring truck? Does the rear drive shaft have a splined slider shaft?
RIP Bob Parks.
Old 11-04-2018, 11:02 PM   #9
hotdog hound
This is a coil spring truck with trailing arms not sure what u mean by the splined slider shaft thats a new one on me. Will have to check it out tomorrow after work thanks
Old 11-04-2018, 11:49 PM   #10
Hidesertchevy
Slip yoke
Hidesertchevy is offline   Reply With Quote
Old 11-05-2018, 12:28 AM   #11
HO455
Post Whore
HO455's Avatar
Most stock 1/2 ton coil spring drive shafts are fixed length on both ends. (1st photo) The leaf spring trucks and 3/4 ton coil spring trucks have the splined slider on the rear shaft. (2nd photo bottom shaft)
When your truck's suspension moves up and down the drive shaft has to move forward and aft. A trailing arm set up has the least amount of forward and aft travel (as compared to leaf spring set ups) so GM was able to cheap out and not put a slider in the shafts. I believe the 3/4 ton torque load would be more than the 1/2 ton carriers would be able to handle.
The movement is taken up by the yoke on the transmission tail shaft. The carrier bearing is fixed to the drive shaft and the rubber mount for the bearing allows the bearing to move. If your truck is not at stock height the rubber may be maxed out at rest and then when the suspension travels it may force the carrier bearing to far and then the mount flexes until it fails. The replacement carrier bearings available today seem to have a stiffer rubber compound than the OE ones did which would add to the failure rate of the bearing mount. The 3/4 tons and leaf spring trucks have a different arrangement where the carrier bearing is fixed and the forward and aft movement is taken up in a splined section in the rear drive shaft. Thus the for and aft movement places no load on the carrier bearing.
I converted my 1/2 ton Burban to the splined slider style with an aftermarket billet to solve this problem. (3rd photo)
RIP Bob Parks.
Old 11-05-2018, 06:37 AM   #12
72freak
Rottenwood Garage Member
72freak's Avatar
We weld every one out of the box before installing!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
