Old 11-04-2018, 08:39 PM   #1
clbmcgov56
drive shaft
how do you remove front drive shaft on a 1972 chevy blazer
clbmcgov56 is offline   Reply With Quote
Old 11-04-2018, 09:47 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: drive shaft
You will get more responses if you post this on the Blazer site....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-05-2018, 06:07 AM   #3
my kids toy
Re: drive shaft
un bolt it, maybe jack the frame up to get clearance, don't jack the axle up.
my kids toy is offline   Reply With Quote
Old 11-05-2018, 06:46 AM   #4
jjzepplin
jjzepplin's Avatar
Re: drive shaft
Mine had 1/4 inch 12 point bolts on the transfer case side and are o mutha to unbolt. I used a small box end wrench of good quality and put one of the front hubs in lock position and the other in unlock as well as the case in neutral to move the shaft by hand. Then when you get you bolt exposed, lock the other hub and unbolt, repeat until you cramp up! haha! If I have to do it again I will swap the front flange to a nut and bolt type and never look back. I thought of this right after I sold a t-case with that flange on it. DOH!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-05-2018, 12:17 PM   #5
jeffahart
jeffahart's Avatar
Re: drive shaft
Two choices: remove the hump for easy access, or fight with it.
j
White K20
jeffahart is offline   Reply With Quote
