11-05-2018, 08:01 PM | #1 |
crossmember does not fit, need advice
Hello to all. I have been reading many of the threads and wanted to introduce myself and see if anyone can help me out. I have a 1970 C10 chevy pick up that I am putting in a new motor and new TH400 transmission. Since I am going from a manual to an automatic trans I knew I had to change the crossmember. I ordered a tubular one from LMC supposed to be for 1967-1972 Chevy C10. I am at my witts end with this as it seems my chassis frame is 3/4" shorter than the crossmember!! Has anyone encountered this and have a solution as to how to get it to fit? Thanks in advance for any and all suggestions.
PS, My Chevy has been named Lil Dicey.. I will post some pics when I get a little further on. |
11-05-2018, 08:25 PM | #2 |
Re: crossmember does not fit, need advice
Try fitting the original CM. You might have to move it but trans mounts aren't too different.
11-05-2018, 08:33 PM | #3 |
are you switching to an 8 cyl from a six I had to move my motor mounts to the front holes then the trans mount holes lined up with the rear most holes I used the tubular mounts and have a turbo 400 otherwise you will have to drill new holes for the tube trans mount
11-05-2018, 09:21 PM | #4 | |
I just wanted to see if anyone else has had the same problem. |
11-05-2018, 09:26 PM | #5 | |
11-05-2018, 09:55 PM | #6 |
I went from the three speed manual to an automatic and had to cut out the crossmember as well. The new crossmember was pretty tight and a trick to install but not as tight as you indicate. One idea is to use a bottle jack and a spacer of sorts between the rails to see if you can get the frame to spread just enough to fit it in there. Work safe however.
11-05-2018, 10:34 PM | #7 |
interesting i have a frame in the garage I’m restoring im going out to take some measurements and pics for you...stay tuned
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-05-2018, 10:40 PM | #8 | |
Its a Truck Thing......
I had the same issue with a 70 LWB that I converted from a 3spd manual to a 700R4. Ended up cutting the ends off the new crossmember and welded up some square to make it work. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-05-2018, 11:18 PM | #9 | |
then my CM can’t remember who i bought it from ill check my records its snug but i can move it inside the frame rails enough to scratch it as you can see i have just mocked it up i wont drill my holes until i put the cab on to see where my HEI ends up to the firewall but thats my issue not yours here are some pictures looks like outside demension from rail to rail is approx 34 let me know wht you measure hope this helps
11-05-2018, 11:44 PM | #10 |
one last pic the c-member is approx 33 3/16 end to end i used a couple of clamps to get a better measurement ...and your crossmember measures what ?
11-05-2018, 11:53 PM | #11 |
Even though you’re only mocked up zicc, you realize your tranny yoke is likely too far out of the splines.
Something else to look out for. |
11-06-2018, 12:14 AM | #12 | |
link to post i hope http://67-72chevytrucks.com/vboard/s...d.php?t=772471
11-06-2018, 12:18 AM | #13 |
just looked at that old post you did give me some good advice its a senior moment for me haha they come mor often now LOL thanks
Jess
11-06-2018, 07:35 AM | #14 |
I don't think the weight of the cab etc is going to be enough. Clean up the rest of the yoke and see how far it goes in before it bottoms out. Then pull it out about 1"-1 1/4".
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
11-06-2018, 11:04 AM | #15 |
Thanks for all the info. I am excited to go out to the shop and try out some of the ideas. Zicc1835, your pictures are very helpful as they look real close to the ones I took and measurements look the same. I will let you know how it goes later on.
1970 C10 Stepside 1970 & 76 C10 Stepside 2000 Chevy 1500 4WD & 2000 Chevy Tahoe 1986 3/4 Ton Flatbed & 1986 C30 Flatbed w/ 8'6" Plow 1988 K30 w/ 8' Plow & 1992 1500 w/ 7'6" Plow 1993 Chevy w/ 7'6" Plow & 1993 2500 w/ 8' Plow 1998 Chevy 8' Plow &2005 Chevy 2500HD 8.1 9'6" plow |
11-06-2018, 01:42 PM | #16 |
When I replaced my crossmember the holes were about 1/8 off. I got a 2x4 and cut it a little long so that I could hammer it in like a wedge to spread the frame. Granted I only had to spread my frame 1/8.....3/4 is a much larger gap to compensate for so you might need to do some cutting/welding on the crossmember
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
11-06-2018, 03:31 PM | #17 |
At the body shop.
Spread the rail with a porta power. These frame are super flexible and move a bunch
" That didnt make it any newer " " Dont antique the equipment " |
11-06-2018, 04:41 PM | #18 |
Whew!! Thanks to everyone for the advice. Porta Power and a little persuasion from the BFH and 1 beer a few cuss words and it is in!!! Thanks again, now onto making the torque converter match up.
11-06-2018, 04:49 PM | #19 | ||
"I ain't nobody, dork."
Even stock automatic crossmembers have to be installed with a BFH and a block of wood.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
