Old 11-05-2018, 08:16 PM   #1
61K10
61K10's Avatar
73-87 spring bushings
Ok i don't know much about 73 up axles. Friend has a 73 3/4t 4x4 4sp truck . So my question- changing the ft spring bushing easy? Stock rubber or urethane? How about ft axle u-joints? Pretty simple--remove everything from the knuckle-pull axle out? Pretty much like a closed knuckle i would think.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-05-2018, 11:13 PM   #2
sweetk30
sweetk30's Avatar
Re: 73-87 spring bushings
yep about the same as closed knuckle .
and if you want to fight stock rubber style bushings go for it . but i just do these guys bushings . http://www.offroaddesign.com/catalog/hdshackles.htm
make sure you KNOW what spring eye size's you need . they will get you hooked up .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-06-2018, 09:12 PM   #3
GSP7
GSP7's Avatar
I think we all have urethane on our aftermarket 4" etc springs with no issues. Least The urethane work great for me
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is online now   Reply With Quote
Old 11-07-2018, 02:35 PM   #4
61K10
61K10's Avatar
this whole tk is a mess. Looks like the ft spring bushing was replaced with the rear shackle ones? There is no metal/rubber one in the spring eye. Looks like 2 rubbers. front x-member has been torched for some reason. any body have a pic of a stock x-member pic with the eng out? just trying to help sort his mess out.
1961 chevy K10
Old 11-07-2018, 04:09 PM   #5
sweetk30
sweetk30's Avatar
73-87 solid axle trucks have a known problem with the engine crossmember cracking / breaking under hard use .
offroad design offers a nice bolt in replacement unit . http://www.offroaddesign.com/catalog...rossmember.htm
