Old 11-06-2018, 09:59 AM   #1
DelawareC10
Rear Floor to Cab Braces??
Replacing the Floor in my 67 Cab, cannot find a definative answer on why some cabs have the braces between the rear of the cab and the floor like pictured below. Mine has them but the drivers side is in pretty bad shape. Are these year specific, model specific, option specific? I am trying to locate a used one for a replacement
DelawareC10 is offline   Reply With Quote
Old 11-06-2018, 01:37 PM   #2
chewychevy67
Re: Rear Floor to Cab Braces??
All the 67s I've ever had had them. I've never owned a 68 but have had 2 69s that both didn"t hahe them. Not sure why the change but it makes it a bit easier to replace the floor with them on.
chewychevy67 is offline   Reply With Quote
Old 11-06-2018, 02:50 PM   #3
DelawareC10
CHEWYCHEVY67 thanks for the reply, I thought originally it was year specific myself but I posted this same question on a Facebook C10 Page and got numerous responses.
1 guy said they were a C20 thing, said his 68 C20 has them.
1 guy said they were GMC only
1 guy said they were for larger fuel tank mounts, nothing to do with cab structure??
Old 11-06-2018, 03:20 PM   #4
aggiegrad
aggiegrad's Avatar
For the record my 68 gmc 1/2 ton had them. I know this doesnt solve all questions. But it is another data point.
aggiegrad is offline   Reply With Quote
Old 11-06-2018, 04:37 PM   #5
clay68c10
clay68c10's Avatar
My 68 1/2 ton 2wd 292 cab had them
71 cab does not
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-06-2018, 05:33 PM   #6
DelawareC10
So, the only trend I'm seeing is it seems to be only the 67-68 Cabs that have them
Old 11-06-2018, 06:04 PM   #7
gearheadperkins
gearheadperkins's Avatar
I dont have them on my 72. I do the like the added brace
1972 Chevy C10 400sbc 4sp
Matthew 4:19
And he saith unto them, Follow me, and I will make you fishers of men.
gearheadperkins is offline   Reply With Quote
Old 11-06-2018, 06:06 PM   #8
FirstOwner69
FirstOwner69's Avatar
My '69 3/4 ton Chevy (built Dec. 1968 at Fremont) does not have them.
FirstOwner69 is offline   Reply With Quote
Old 11-06-2018, 06:32 PM   #9
darrellyates
For the record, I've had 3 of these trucks. None of them had them. I know that 2 of them were from Baltimore. I've had a 1968; and two different 1970 model trucks. The '68 and one of the 70's were 1/2 tons, and the second '70 model was a 3/4 ton. NONE of them had these braces.
Again, just data points. I put a floor in one of the '70's trucks, but did nothing to the floor of the others. Please note, I was not the original owner of any of these trucks, but took all of them completely apart. I believe they were original.
Good luck figuring it out.
darrellyates is offline   Reply With Quote
Old 11-06-2018, 08:37 PM   #10
Thrill4130
Active Member
Thrill4130's Avatar
My 67 c10 has those braces also.
Thrill4130 is offline   Reply With Quote
Old 11-07-2018, 12:36 AM   #11
buildingmy68
I have a 3/4 ton Chevy, it has them and they are some serious reinforcement
doesn't answer but maybe the gas tank support quote is good logical point.
buildingmy68 is offline   Reply With Quote
