Old 11-06-2018, 02:32 PM   #1
scoobiedoo01
67 C10 step side exhaust ideas
I'm in the middle of finishing up my 67 C10 step side and am trying to figure the best route to plumb the exhaust. I'm running 3" pipe all the way back and thinking of running the exhaust through the rear quarter panel either just before or after the tire. Do any of you guys have any pics of yours that I could see for ideas?
scoobiedoo01 is offline   Reply With Quote
Old 11-07-2018, 03:25 PM   #2
benw88
Those are the best pics I have at the moment. I have 2.5” pipes that kick out at roughly 30 degrees, then I have a SS exhaust tip that is cut off at 45degrees so it’s flush with the bottom of the step on each side of the truck. The tip is 3”
benw88 is offline   Reply With Quote
Old 11-07-2018, 04:00 PM   #3
mr.precision
mr.precision's Avatar
Re: 67 C10 step side exhaust ideas
Original 1967 stepper. Dual exhaust is at least 20 years old. Hope this helps.
mr.precision is offline   Reply With Quote
Old 11-08-2018, 09:58 AM   #4
68Stepbed
68Stepbed's Avatar
Take it out the rear!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-08-2018, 12:38 PM   #5
michael bustamante
michael bustamante's Avatar
68stepbed. I like where you dumped em I might do that too!
67 GMC
1967custom
michael bustamante is offline   Reply With Quote
Old 11-08-2018, 03:36 PM   #6
scoobiedoo01
68Stepbed. I like this set up. What size pipe are you using? I want to run 3" all the way back and right behind the tires would be just right if 3" will fit okay.
Old 11-08-2018, 08:01 PM   #7
Mike C
Mike C's Avatar
IMO, you will be much happier all the way around if you run a 2 1/2" system rather than a 3". Cost is WAY higher for the 3" and much more difficult to route. If you are making 600hp and need it then I guess... But I'm planning a 2 1/2" system behind my 450hp 427.
I too am a "run it out the back" guy. On my leaf spring truck I cut holes in the crossmember where the trailing arms would bolt and I welded in 4" pipe reinforcements and will tuck and run my exhaust as high as possible.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-09-2018, 12:01 AM   #8
HO455
Post Whore
HO455's Avatar
I agree with Mike C about sizing. I ran mine out Zoomie style on my Burban to keep the exhaust out of the interior. My rear hatches barely keep water out let alone fumes. Sorry about the poor photos
RIP Bob Parks.
Old 11-09-2018, 09:25 AM   #9
68Stepbed
68Stepbed's Avatar
Mine is 2.5" pipe. I have a 530hp LS1 and these breathe very well. As Mike C mentioned, 3" is overkill unless you're making above 600hp. That said, 3" is difficult to route to the back, but it's possible for someone that knows what they're doing. My TCI rear suspension created an even more complicated routing scenario than stock suspension, so the stainless mandrel bent setup was the only way to go.
Matt
Old 11-09-2018, 09:31 AM   #10
68Stepbed
68Stepbed's Avatar
The best part is the exhaust is tucked and isn't seen at all.
Matt
Old 11-09-2018, 11:26 AM   #11
scoobiedoo01
68Stepbed. That is exactly what I want. Nothing hanging down at all. Nice looking truck!
Old 11-09-2018, 09:19 PM   #12
Mike C
Mike C's Avatar
I assume his TCI suspension has clearances for the pipes through the center crossmember. I know the drop-members are made that way. Here is my mods to my truck. Leaf springs make it easier...
And these made me chuckle. The pieces I cut out pretty much were Pacmen.
44 Willys MB
52 M38A1
64 Corvette Coupe
