11-06-2018, 07:10 PM | #1 |
Dodged a Bullet, Maybe. Overheated badly.
Long story for anyone bored.
I spent a long hard day in the orchard and let off my 2 helpers and hit the freeway a happy camper. I kept smelling an odd odor, sort of like the air that comes out of a tire, just a faint smell, nothing alarming. I though it must be some truck up ahead, but it never went away. So a few miles later I come down the off ramp and just HAPPENED to check the temp gauge. Well heck, it looks like that wire coming off of the sending unit has shorted out or come loose again because the temp gauge is PEGGED to the right, way past the "HOT" zone. Then when I came to a complete stop I saw little wisps of steam coming out the side of the hood. So I headed to the service station about 100 feet away and shut off the engine. POOF!!!!!! the radiator seams let go and it looked like the gun-camera scenes from WWII when a steam engine locomotive is nailed my a fighter. HUGE cloud of steam enveloped the poor couple in the row next to me. It just kept billowing out until it was all boiled out I assume. This was fresh 50-50 green coolant. So I waited a little while (NOT long enough for sure) and took the jug of ice-water in the back and slowwwwwly poured it in with the engine restarted. I heard all kinds of "bad" sounds and it too boiled out immediately, surging out the fill hole. So eventually I got it to take enough water to limp it home a few blocks away. It was the fan belt that somehow got off and I was running with no water pump or fan (for how long I don't know). Today I found a local shop that re-soldered the seam and added a brace top to bottom for added support. This is a brass 4 row. He fixed up some other issues and pressure tested it. $45, 30 day warranty. While we was working I got new belts and a new thermostat, $8 but they wanted $10+ for the gasket !!! So I got a $3 one from Auto Zone. Anyway I got it all together and it APPEARS to run fine. No water in the oil (YET). There is a noise that sounds like a loose belt or a wet belt down by the timing cover and I suspect a loose timing chain (It makes the noise with no belts installed). The test will come when I get it out with a big load on a hot day I suppose , but for now I am a happy custom camper once more (minus about $100). -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
11-06-2018, 07:47 PM | #2 |
Re: Dodged a Bullet, Maybe. Overheated badly.
Hopefully it lives on! If you have an oil pressure gauge that is the one I would keep an eye on now. I overheated and engine and thought it was ok but once it warmed up my oil pressure dropped to about 5 because I had wiped out the bearings. However I think I got it even hotter than you did! If the oil pressure is good, then I think you got away with it!
Small blocks are tough!
11-06-2018, 08:07 PM | #3 |
Good point. I need to fix my aftermarket oil gauge. Tomorrow's project I guess.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 11-06-2018 at 10:37 PM. |
11-07-2018, 03:39 PM | #4 |
I'd be wondering why the fan belt jumped track in the first place. Check the alignment of all pulleys along with checking all bolts that hold the pulleys/accessories/and accessory brackets in place. A loose bolt or two could cause just enough miss alignment of pulleys to throw a belt. Good luck.
11-07-2018, 05:06 PM | #5 |
I would change the oil, I'm sure it got pretty hot also.
11-07-2018, 05:54 PM | #6 |
Good point Garyd1961. It's due anyway.
Oil pressure looks good this AM. I have yet to build up any pressure in the cooling system to see if there is a crack. Also concerned about the noise at the timing cover area.
