11-19-2003, 02:37 PM | #1 |
Headlight Problems... any idea's???
Truck: 72 K-10. I went out to start my truck last night and the headlights refused to go on. All other lights work. I looked at the fuse panel and no blown fuses. The little 4 amp fuses on each side in the engine compartment above each lamp in the black w/ white stripes wires are fine. I'm not sure what else it could be??? Any anyone have any idea's???
Alex 1971 Lil' Red 350 SBC 700R4 |
11-19-2003, 02:44 PM | #2 |
67-72 Addict!
Check the ground on top of the core support on the passenger side. Unbolt it and scuff it. Also check the dimmer switch for corrosion on the floor.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 11-19-2003 at 02:46 PM. |
11-19-2003, 03:04 PM | #3 |
I'll bet it's the dimmer switch wiring mine, was a little melted and corroded and gave me the same results.
PR Too many projects, not enough time! 72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold! 69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam. 78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's 77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs |
11-19-2003, 03:18 PM | #4 |
Formerly yellow72custom
I third the dimmer switch...they are notirous for going out and making your headlights now work. They only cost like $4 though
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
11-19-2003, 03:42 PM | #5 |
You guys are both right!!! Wiggled on the dimmer switch and the freakin lights went on. Thanks Tons!!!! Gonna order a new switch right now from Pauls.
Thanks again you guys!!!
11-19-2003, 06:56 PM | #6 |
F.Y.I.
GM stills makes the floor mounted dimmer switch for our trucks, Picking mine up tomorrow.
11-20-2003, 12:57 AM | #7 |
its all about the +6 inches
Your local parts store probably has them too.
