Old 11-08-2018, 06:33 AM   #1
44th Miss Inf
Door flexing
Moved one of my crew cabs recently and noticed when I opened the driver's side door, the door skin flexed a good bit (probably close to an inch) in front of the door handle. I didn't have time to tear into it, but did check the passenger door and the doors of my other 3 square bodies and none of the others flex like that one does.
It's been a while since I have been in the doors of a square but I don't remember any brackets or braces to prevent this.
Will try to tear into it this weekend as I'm off. Is there a bracket in there I may be missing? I hate to take panels off a few doors to compare but will if I have to.
44th Miss Inf is offline   Reply With Quote
Old 11-08-2018, 06:26 PM   #2
74CustomK20
74CustomK20's Avatar
Re: Door flexing
Mine did that, and the little rollers on the door hinges had froze up. Keep it up, and they'll fold in the metal on th front of it where they bolt up. I'd try that first. Little wd40
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 11-09-2018, 06:30 AM   #3
Wgesnerjr
Wgesnerjr's Avatar
Re: Door flexing
My original door had this same issue. I remember seeing a "reinforcement" plate on the inside of the door skin. I had thought that plate might have a broken weld or something.
For other reasons I wound up using another set of door to finish my truck, but would start looking at the plate. the side glass was out of mine which made it easy to see it flex.
If there is some kind of weld that's broken, and rewelding is not an option...(like good paint on outside) I would look at something like JB Weld to reattach.
good luck.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
