Old 11-09-2018, 08:40 PM   #1
cebra
SWB Conversion Driveshaft
I have some unique issues with my build as I have limited access to power. With this said, I am doing a SWB conversion in stages. My issue is that once I cut the frame and weld it up I cannot let the truck sit to have the driveshaft cut down (only option is to tow it 20 miles and install driveshaft on the roof of my parking garage). I know where there is a 1968 396/manual trans SWB truck that has a driveshaft. My truck is a 71 350/350 LWB. Does anyone know if this driveshaft would fit once mine has the 12" removed (length/spline/etc)? I have searched a lot and my head is spinning trying to figure this out.
Also related, I am putting in a NV3500 (as soon as I find that unicorn) down the road so if my only option is to cut the DS down now should I convert to 1 piece DS now get it cut down for SWB and then have it cut down again for NV or just have the 2 piece cut down now for SWB and go to 1 piece when I get the longer trans? Thanks.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 11-09-2018, 10:12 PM   #2
HO455
Post Whore
HO455's Avatar
Re: SWB Conversion Driveshaft
You may not have noticed you posted this in the Suburban section. There are only a couple of SWB Burbans around (see Frizzlefry's Tahoe build). You will get more help on the pickup side. Ask a moderator to move your thread.
Good luck.
RIP Bob Parks.
Old 11-10-2018, 11:41 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Moved.
LockDoc
Leon
Old 11-11-2018, 08:59 AM   #4
72LB
72LB's Avatar
I have a th400 currently in my shortbed and am going to a th350 and doing a one piece driveshaft. One of our club members used a driveshaft from a 95 Chevy c1500 with a 5 speed NV3500, it was pretty much a bolt in just had to change the yoke. I'm not sure if it will help but might give you a starting point of sorts.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
