![]() Join Date: Nov 2018
Clutch peddle
Hey
Swapping my TH350 for a MH 465 Does anyone sell a clutch pedal separate all I can seem to find is the entire brake/clutch assembly? Thanks |
Re: Clutch peddle
In the same boat however I am doing the NV4500 all I find is the brake/clutch pedal set. Looks like that's what I am going to do /shrug
Re: Clutch peddle
IMO, the easiest / best solution is to replace your pedal hanger with a stock clutch/brake pedal hanger, you'll also need all of the associated parts/linkages. Easiest way is with a donor truck or you can place a "want to buy" on the parts board (I think you need to be a supporting member, someone correct me if I'm wrong). Someone may be changing from manual to auto & the two of you can swap parts.
Welcome to the forum! |
#4 | |
Re: Clutch peddle
I found the transmission from someone changing to auto but they kept the pedal as it was one of those polished aluminium ones they did give me all the linkage though. |
#5 | |
The Older Generation
Re: Clutch peddle
I'm not familiar with the MH465, could you possibly mean an SM465? If so, you will probably need a bell housing cross member to support the rear of the engine..... LockDoc
#6 | |
Re: Clutch peddle
Already have the cross member on the transfer case I'm going from 454/TH350/NP205 to 454/SM465/NP205 I found a NP465 that came with the NP205 it was installed with. |
Re: Clutch peddle
Please note, that I did not authorize this note
"Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help." A fellow member was looking and I told him to PM me if interested, isn't that the intent of these forums, to help new members out? If we have to pay to exchange information, then it seems the point of the forum is lost, just saying. Last edited by my67c20; 11-12-2018 at 06:18 PM. |
Re: Clutch peddle
I just installed an NV3500 with a hydraulic clutch. I have a bigger brake booster so I had to put the master over on the seam edge. I made the ear looking reinforcement piece to brace the master. I drilled a hole through the brake pedal 2 1/8 down from the pivot and made a spacer from the pedal to the master rod. Does this help?
Do it, Do it right, Do it right the first time |
#9 | |
Re: Clutch peddle
#10 | |
Re: Clutch peddle
when do I get my swag? ![]() |
Re: Clutch peddle
![]() LockDoc
