11-11-2018, 11:32 AM | #1 |
Help! Bolt in exhaust pass through?
I've seen these here on several member's trucks. They bolt into the crossmember and allow the exhaust to pass through. Can somebody tell me the company that make these? Thanks in advance.
11-11-2018, 11:36 AM | #2 |
Re: Help! Bolt in exhaust pass through?
11-11-2018, 04:11 PM | #3 |
Brothers also has them.
https://www.brotherstrucks.com/63-72...tinfo/ECOB072/ |
11-11-2018, 05:39 PM | #4 |
Unless you have 1000 HP you don’t need them
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-11-2018, 07:03 PM | #5 |
Post Whore
I'm not sure of your logic here. Can you explain further?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-11-2018, 07:09 PM | #6 |
I'm pretty sure he's talking about frame twist without bolting or welding in tube support after cutting cross member . I just cut 4" holes and welded in tube support total cost was $20.00 for the tube . A lot of these old trucks have "chevy twist" in the frame with stock engines ,So throwing a 1000 at a stock frame holes or not will probably have the frame looking like a pretzel .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-11-2018, 07:39 PM | #7 |
There is a member here, can’t recall his handle, that cut holes in his crossmember and has been running it that way for several years without reinforcement and he has a healthy big block IIRC. I cut 3” holes in mine instead of 4” and don’t plan on reinforcing it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 11-12-2018 at 11:41 AM. |
11-11-2018, 07:44 PM | #8 |
All I did was hole sawed two 3" holes in the cross member with out welding any thing. I use 3" exhaust which was a very tight fit and the holes act as the hangers. I'm throwing at least 600 hp through the pipes and my frame still looks good. The paint isn't even burning off.
11-11-2018, 08:29 PM | #9 | |
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
