11-13-2018, 03:53 PM | #1 |
LS swap question
I’m about to do an LS swap. As far as mounting the motor are there any modifications I will have to do to the firewall or anything else or does it bolt right in with the new motor mounts? Thanks in advance.
11-13-2018, 06:46 PM | #2 |
Almost Satisfied
Re: LS swap question
Welcome to the board. No modification to the firewall on my 71. Not sure what year or LS you are working with. One thing I can tell you is to do plenty of homework. Know your AC plan, your header plan, your engine mounting plan, etc. Each piece will impact the next one. I used POL engine stands with LSX innovation adjustable plates. Kept the engine in near the same spot as the original small block. Good luck.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-13-2018, 07:05 PM | #3 |
Post Whore
/\/\/\..what he said....what yr truck,what trans?...more info please..don't expect everything to just bolt back together...remember these engines/trans wernt designed for our old trucks..
11-13-2018, 11:20 PM | #4 |
I put a LC9 with a 4l65e tranny in my 1970 C10. I bought motor and transmission mounts from BRPhotrods inc. See http://www.brphotrods.com/.
This was 'bout 4 years ago - I now see they have all sorts of kits. It bolted in with no mod to frame nor body. It also has the correct trunnion angle. A 90 chev drive shaft with an adaptive u joint fit - no vibrations. Lots of luck with project. |
11-13-2018, 11:45 PM | #5 |
I haven’t bought the LS motor yet, I have my current motor and tranny sold, just waiting to find the right one. I have a 68 shortbed stepside 2wd. I am probably going to go with a 5.3 with the 4L60e tranny just because the 6.0 with the 4L80e is a lot more expensive. Thanks for the advice guys.
11-14-2018, 03:45 PM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
Nick,
Don’t count the 4.8 out! I have one and it gives plenty of power for me. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-14-2018, 05:35 PM | #7 |
I’ll keep that in mind Clyde.
11-17-2018, 06:24 PM | #8 |
I also agree with Clyde, very happy with my 4.8. All I need!
tbrown's 56 Cameo Build |
