Old 11-13-2018, 09:57 PM   #1
ronm69c10
rough starting
69 c-10 with 84 454 rebuilt 10,000 ago.installed a rebuilt 800 cfm quadrajet with electric choke,and holley fuel pressure regulator. car start's after 2 pump's of the gas pedal.run's rough till warm-up which take.'s a good while.then once it has warmed up it run's fine.the idle is a tad high. any help with my problem would really be helpful. thank's ron
ronm69c10 is offline   Reply With Quote
Old 11-13-2018, 10:04 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: rough starting
Is there a thermostat installed?
What temp thermostat?
Timing set to?
Type of distributor?
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-13-2018, 10:12 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: rough starting
How are the choke and choke pull-off assembly adjusted for your climate?
~Steven
Simi Valley, CA
Old 11-14-2018, 03:36 PM   #4
ronm69c10
Re: rough starting
180 thermostat,timing good,hei, truck runs between 180 and 185 in 60 to 90 degree weather
Old 11-14-2018, 03:50 PM   #5
geezer#99
geezer#99's Avatar
Re: rough starting
Your choke is too rich.
Adjust the choke pull off.
geezer#99 is online now   Reply With Quote
Old 11-14-2018, 06:46 PM   #6
ronm69c10
Re: rough starting
Have not touched choke since I received carb from rebuild shop,was engine tested I was told. However your ideal sound's like the best place for me to start. I was getting gas fume's in cab,not from gas tank. Now I get to learn a few thing's about quadrajet choke's. THANK'S FOR THE TIP. I WILL LET YOU HOW THIS TURN'S OUT RON
Old 11-14-2018, 06:54 PM   #7
ronm69c10
Re: rough starting
Thank's for your quick reply,and I think you are right. I have not done anything to carb since I installed it. Choke pull off adjustment is Thursday job.THANK'S AGAIN ,I'LL LET YOU KNOW HOW IT GOE'S RON
Old 11-14-2018, 07:02 PM   #8
geezer#99
geezer#99's Avatar
Re: rough starting
Easy to find where your choke blade has to be set at.
While it’s warming up just move the blade by hand and find the spot where the idle smooths out. Then adjust the linkage to it.
And before you start bending linkages take a pic of your choke for us. Might be a simple screwdriver adjustment.
Old 11-14-2018, 07:50 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: rough starting
Indeed!
~Steven
Simi Valley, CA
