11-14-2018, 12:58 PM | #1 |
250 or 350
Background: I’ve got a 70 with a 250 3 speed. Engine runs well enough, but it could use a refresh (read: I just want to build an engine). Debating between rebuilding the 250, maybe hopping it up a little, or building a 350.
250 advantages are known “good” engine and it’s a little bit different. 350 advantages are, well, 2 cylinders and parts availability. Any input? |
11-14-2018, 03:56 PM | #2 |
Re: 250 or 350
I'm a big fan of the straight sixes. If it's all original I'd be inclined to keep it that way. If it's a "parts / pieces" truck I'd build a 350. All things equal, cheaper to build / more HP per $. Just my opinion.
11-14-2018, 04:17 PM | #3 |
Re: 250 or 350
I’m in the same boat. Motor is original and truck is in good shape but has been painted etc over the years. Not parts and pieces but not a period correct truck either!
11-14-2018, 04:18 PM | #4 |
Re: 250 or 350
You'll also need to change a bunch of stuff like perch locations and motor mounts for the 350. If it were me and I wanted to keep the truck, I'd put in the 350 because I like more power than the 250 is capable of producing without a lot of work and money thrown at it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-14-2018, 05:49 PM | #5 |
Re: 250 or 350
If you are on a budget, go 350. It is not cheap to rebuild a 6, especially if you're wanting to "hop" it up. I'm in the middle of that right now.
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
11-14-2018, 06:33 PM | #6 |
Go Pack Go!
Re: 250 or 350
It will take deeper pockets to get 400+ HP out of a 6, but the attraction it brings at car shows and the neck snapping sound one makes is very different. Clifford is the 6 guru for performance parts https://www.cliffordperformance.net/
11-14-2018, 06:53 PM | #7 |
Re: 250 or 350
I'd throw the l6 in the trash heap and replace it with a proper V8.
...You asked. |
11-14-2018, 08:53 PM | #8 |
Re: 250 or 350
11-14-2018, 09:08 PM | #9 | |
Re: 250 or 350
Yes, they are cheap, but they are so bland and common - if you want a 350, just go buy a mid '90's Chevy and drive it until the wheels fall off. Build the six. If you want more than a 250 can offer, swap to a 292. |
11-14-2018, 09:22 PM | #10 |
Moderator
Re: 250 or 350
Depends on your budget really...
You can spend big dollars on a six and end up with maybe a head turner What is the rest of the truck like? Auto or manual? Brakes? All Drum or Disk Drum?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-14-2018, 09:25 PM | #11 |
Re: 250 or 350
Love 292's not so much 250's.
Was going to turbo a 292 until I found out how much it takes... then just decided BBC. |
11-14-2018, 09:30 PM | #12 |
Moderator
Re: 250 or 350
Smart man!
454 Mark V...just gotta keep it cool....
11-14-2018, 09:45 PM | #13 |
Re: 250 or 350
Truck is a long bed fleet side, 250 with a 3 speed. Floor shift to accommodate Flaming River tilt column and rack and pinion steering. Front disks, rear drum. Just a cruiser and weekend toy. Sometimes it has to earn its keep hauling a bit
11-14-2018, 09:49 PM | #14 |
Moderator
Re: 250 or 350
If you want to keep the 3 speed or keep it manual...build yourself a sweet 292....
If you are open to a V8...there is only one choice in my mind...454 and a TH400... Do the math...the dollars are so close to each other its scary... Personal preference...
11-14-2018, 09:52 PM | #15 |
Re: 250 or 350
If you want bragging rights, drop a V12 drive-line in it. Upgrade the fuel system to fuel injection and you will get better gas mileage than you are getting now.
11-15-2018, 12:25 AM | #16 |
Re: 250 or 350
I've built a couple of strong modified inlines over the years. The unique factor is pretty cool. The downsides: Expensive to make any real horsepower and an affordably modified 250 or 292 still pales in horsepower and fun factor to a cheaper mild 350.
Steve weim55 Colorado |
11-15-2018, 08:17 AM | #17 |
Re: 250 or 350
What's cheaper about buying an engine that needs to be adapted (radiator, shroud, shift/clutch linkage, exhaust, fuel line) vs what's in it? Who said anything about wanting 400 hp or a big block? I would rebuild the 250 that would fill all your needs. It would be a better conversation piece w/speed equipment than just another 350.
11-15-2018, 09:51 AM | #18 | |
Re: 250 or 350
11-15-2018, 09:55 AM | #19 |
Re: 250 or 350
Special K, that’s kind of how I’m leaning. This isn’t gonna be a go fast truck. Keeping the 3 speed for now, if I came across a 4 speed relatively cheap, I’d probably make the swap. I do like the different factor of the inline.
11-15-2018, 10:30 AM | #20 |
Re: 250 or 350
Look for a Saginaw 4spd. They can be had way cheaper than a Muncie. That Sag 4spd will bolt right in. It would serve you well behind a 250 and be way cooler to drive.
11-15-2018, 11:16 AM | #21 |
Re: 250 or 350
I was building a couple L6 trucks because they are cool and I had no plans but to build a couple cruisers ,Then I fell into a great deal on a 4 bolt 350 that changed everything on one build , The "lowly" 250 came out and was sold for $350.00 to a local guy for his 65 and he was happy to get it . The 350 led me down a different path for that truck with switching the manual cross member to the V8 one and then a lower drop for that truck and then a bunch of chrome to add some glitz and floor shift ...I still have 2-292's and a 250 for my other trucks and they'll get used on more stock style trucks like I had planned from the start.Build what makes you happy and fills your needs . ,
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-16-2018, 09:46 AM | #22 |
Re: 250 or 350
Input? Yeah. Could fill your screen several times over but won't bore you with a lot technical details.
Back in the day I rebuilt more of both for fleet service and various walk in customers than I care to remember. Saw heck of a lot more 250 over 200k miles than 350s. A very simple and popular upgrade was the "590" Mercruiser marine cam. Clevite number '1959". Did that to my own monojet carbed 250 in my '69 long stepper. That, good tuning, along with a split header really wakes things up. Sounds good too. As opposed to single exhaust which tends to sound buzzy on the six. Nostalgia. Inlines are having a resurgence in popularity. Taking my truck to shows a lot of guys will walk past a row of v8s just to look at my grimy old inline to talk old days. 'They last forever' and 'can't kill those things' are common comments. Inline are much easier to service in the vehicle too. As for rebuilding. Part pricing has changed much in the last few years. 10-15 years ago you could find master rebuild kits for $189. Not anymore. In case you don't know. Master kit has everything. All bearings, pistons, rings, cam & lifters, gaskets, freeze plugs, etc. Two common oversights I have seen with any engine, not just inline, are reusing old worn valve springs and not checking big end of the conn rods. Have not seen any with with miles on them which were not stretched somewhat. With above said. V8 is definitely the way to go if you want to build power. Much cheaper and easier to get there. You need to sit down think budget and make a list of goals then decide which way to go. Hope that helps.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
11-16-2018, 10:23 AM | #23 |
Re: 250 or 350
What rear gear are you running in it right now? If you're thinking of spending money to change to a 4 speed, you should strongly consider looking for a 5 speed from an S10 to get the overdrive. I'm keeping my 3ott steering column, and I'm running a 3.73 out back, so to get overdrive, I bought a 3 speed tranny w/OD. Yeah, it's old school, but that's how I roll. My main point being, if you plan to cruise your truck down any interstates or freeways, that OD tranny will keep that 6 from buzzing you out of the cab. Just my $.02
11-16-2018, 09:15 PM | #24 |
Re: 250 or 350
OK 57Suburb, this is kinda hijacking the thread but, I'm just starting to look into the Saganaw 3 speed OD behind my 72 C20 3OTT 292 coil spring HO 52 4.57 rear end. Would really appreciate any info you have about doing this. How much longer is the trans? How did you mount the cable and the switch? Etc.. Pictures? Thanks in advance.
11-17-2018, 10:31 AM | #25 | |
Re: 250 or 350
