Squarebody suspension Donors
Are Square body 1/2 ton suburbans good suspension donors for 60-66 pickups?
Any differences in the front end? is the rear end the same width as the pickup, any body used a burb as a donor? |
![]() Join Date: Jan 2011
Re: Squarebody suspension Donors
The only thing I look for when picking a donor is the 1 1/4" rotors. That makes it compatible with most drop spindles and you can get 6 lug rotors. Rears I look for 12 bolts with 3:42 (just my preference) or 3:73 gears. I just use the gears and carriers. I also look for K10's with 12 bolts and see if they have the bigger brakes on em. I use the backing plates, hardware and drums for bolt on big brake swaps on the 6 lug rears.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
What if you are going 5 lug?
Square body 1/2 ton Suburbans (and I believe blazers also) should be 6 lug. For 5 lug stuff, look at 1/2 ton pickups.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
The 2 WD burbs were not 6 lug. Just the K series trucks and Blazers.
Jimmy
| Bookmarks |
