Old 11-17-2018, 01:42 AM   #1
72 K20
72 K20's Avatar
Vacuum water valve
Could someone tell me how many inches of vacuum are required to open the water valve ?
My truck only carries around 10 inches of vacuum at idle and I am not getting much heat in the cab .
Motor runs right around 195 - 200 degrees'.
New heater core , valve, and hoses . One hose is hot ,, the other is warm .
I hooked the valve directly to manifold vacuum and no change.
Wondering if I got a bad valve ............... tomorrow I'm going to try taking the valve out and just splicing the hose together .
Give me some things to check , tips , info !
Thank You ! Tom
72 K20 is offline   Reply With Quote
