Rebuild in progress - can't turn crank?
1965 GMC 1000, rebuilding the 230. Ended up actually needing a new block due to a crack. The new block is cast with a 1968 model year but looks identical.
I have the crank and cam installed. Main bearings torqued to spec (65 ft lbs). Sticky assembly lube on everything (because I don't know any better). I can't turn the crank by hand and I just wanted a sanity check on this before I go any further. Sound right? Bearings are .010 over, new-to-me crank is supposed to be freshly ground to the same by a reputable shop. I tried putting bolts into the flywheel mounting holes on the crank and turning it with a screwdriver, to no avail. I recall when I was disassembling everything, I had a hard time turning the crank in this fashion as well, but it did move. Now it's not moving. I haven't tried my hardest but was worried about f-ing something up. All the caps are in order and the arrows are pointing forward. Tips/suggestions?
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. |
![]() Join Date: Sep 2006
Re: Rebuild in progress - can't turn crank?
did you use plasti gauge to check clearance on the bearings?
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
![]() Join Date: May 2015
I wouldn't go any futher....tear it down and find what's binding..start by removing the center mains 1 at a time leaving the ones on the ends..check to see if it'll rotate by hand with each cap removal..
Did not plastigauge it yet. How hard is it supposed to be to turn?
Moderator
![]() Join Date: Dec 2012
Pretty easy. Something's wrong. Get the mic on it, and do a plastigauge check.
#6 | |
With everything torqued back to spec, I can't move the crank literally with my hand on a counterweight (well maybe I could with greater effort but not "easy" like my camshaft spins), but I can turn the crank by putting bolts into the holes where the flywheel connects and turning it with a screwdriver for a lever. Does this sound right?
No.. You should be able to turn it with your hand. Need to check clearances. You might get some resistance but not that much.
Okay I'll get some plasti gauge. But whats next if clearances are too tight? Drop another $60 on different bearings? Send my crank back to the shop and tell them **** doesn't fit?
![]() Join Date: Sep 2016
Did you use oil on bearings?
I know a guy that had this issue. In this case the machine shop turned all the journals except one so when he put the oversized bearings on it would not turn.
![]() Join Date: Dec 2009
Your block may need align honed. Talk to the shop that you took it too; they should be able to help you.
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
#12 | |
Moderator
![]() ![]() Join Date: Aug 2011
When I was 15 I rebuilt a 327 and did the same thing your doing. Didn't Plasti-Gauge the bearings. I just bought a set and put it together. Well it didn't turn over either. A local engine builder (very patiently) showed me what I was doing wrong and fixed it. Of course he had me as his scribe the whole time. Like I said he was patient. Wow I almost forgot that guy...
#13 |
Mike the bearings. It doesn't happen often but sometimes the wrong bearing is put in the box. Keep checking sill you find what is binding
#14 |
Moderator
To clarify... two of us have said to mic/mike the crank. If you don't know what that means, let's help. Get and use a micrometer to measure each of the crank journals.
https://mobiloil.com/en/article/car-...the-bottom-end
#15 | |
#16 |
Take it back to the machine shop...they'll have all the proper tools to find out what's going on...
It could be wrong bearings..crank turned wrong,bore line...or whatever...but you should be able to turn it by hand with minimal resistance....even if you had rods and pistons on it you should be able to hand spin it..
#17 |
I don't know what kind of rear main seal you have, but loosening #6 might indicate that the seal, if it is a rope type two-piece is doing what it is supposed to be doing.
#18 |
The #2 cap and #6 cap, when torqued to spec (65 ft-lbs), cause me to not be able to turn the crank by hand. If I loosen these two, with everything else still torqued, it turns quite easily.
I plasti-gauged these two. As best I can tell, they are in spec, at 0.00125 (roughly halfway between .0015 and .001) I guess this indicates that I need to have the shop check and possibly align-hone the block? Is there something else that could be going on?
#19 | |
I've even heard stories of crankshafts getting warped by leaning them against something. They don't like it. Something about them turning up their nose at such rude treatment. Last edited by kazoocruiser; 11-18-2018 at 09:46 PM. |
#20 | |
#21 | |
#22 |
![]() Join Date: Jan 2011
The only way to fix this correctly is to measure everything. To check the crank you need a 1" to 2" mic for the rod journals and a 2"to 3" for the mains. Borrow mics with the .0001 scale on them. Measure all the journals size, out of round and taper. Write down all your measurements and make sure it is with in spec. Next you will need a dial bore gauge. Put on the main caps with out the bearings and torque them to spec. Check the bores for size and out of round and verify they are in spec. Now repeat the process with the bearings in. The difference between the crank measurements and the bearing measurements is your true clearance. With this information you can get to the true issue. They could range from a poor grind to miss marked bearings. I don't use plastigauge as it only tells you what you have and not why.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#23 | |
All of that is useful information, but only if the crankshaft doesn't have a warp in it. None of those measurements will pinpoint out of alignment main bearing journals. The crankshaft has to be tested on v-blocks or a lathe and measured for runout |
#24 |
![]() ![]() Join Date: Apr 2012
.00125 to .0015 is not enough clearance. Should be .002-.0025. One thing I have to ask. When you put the main bearings in , did you put them in dry and super clean OR wet and oily against the block ?
https://67-72chevytrucks.com/vboard/...1966+gmc+panel IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#25 | |
This contradicts what the GMC Maintenance Manual says for clearance, which shows 0.0003" - 0.0019".
![]() Quote:
In any case, I dropped the block and crank off at the shop and they're going to take a look for me.
| Bookmarks |
